very cool cam install video, dyno, etc
Old 07-01-2005, 06:33 PM
BigSteele's Avatar
Default very cool cam install video, dyno, etc
Well I finally stopped being lazy and put up some videos I had. go to my site
http://www.darmer.com/videos%20main.htm
cam install was going to be a time elapse kind of thing but I realized that you couldnt see the important stuff, so I moved the camera. (and skipped some stuff on the reinstall due to my excitement) BTW cam is F14
you can check out some pictures I have if you want to, go to http://www.darmer.com and look around
hope you like it!
Old 07-01-2005, 06:45 PM
Roarin_8's Avatar
Cool vid, wish I had a place to change mine.
Old 07-01-2005, 06:46 PM
BigSteele's Avatar
just some other info,
I used wooden dowels to hold the lifters up, but as you can see in the video, it took a decent amount of finger pressure to pop them back down, (everyone was like that)
I got the oil pickup tube bolt back on my first try.
I really cranked the balancer bolt with all my might it was very hard to turn the extra degrees (listen for sigh of relief in video)
Old 07-01-2005, 07:06 PM
FILE's Avatar
Nice video. What size of dowels did you use?
Old 07-01-2005, 07:38 PM
BigSteele's Avatar
how can you not find a place? it was done in my home garage, as long as its not raining, you can even do it outside I guess.
The dowels were both 5/16". I slightly "pointed" the tip and lightly sanded the length to remove burrs. cost less than $2
Old 07-01-2005, 09:12 PM
Roarin_8's Avatar
No time and no garage. I have to send it out to get it done.
Old 07-01-2005, 09:25 PM
Stroker 1500's Avatar
The valve train seemed a little noisey to me... It sounds like the preload isn't set quite right.
Old 07-02-2005, 03:19 AM
BigSteele's Avatar
kind of sounds loud like that in the video, but if you listen to it it sounds ok, I was expecting the setup to make more noise.
Old 07-02-2005, 07:35 AM
GuitsBoy's Avatar
Did mine in the driveway in a day and a half w/ new pump and chain. Could have finished in a day if i didnt take so many pool and a/c breaks.
DO IT!!!
Old 07-02-2005, 07:37 AM
GuitsBoy's Avatar
Big Steele, Nice vids. What other mods do you have? What kind of dyno were you on? 374 HP seems a little light for an f14 if you have full boltons. Not trying to **** on your parade, just curious.
Old 07-02-2005, 07:39 AM
GuitsBoy's Avatar
One other thing... Did I see you put oil in the rocker bolt bosses? Maybe youre hydolocking those bolts and thats why your preload is off...
Old 07-02-2005, 10:44 AM
BigSteele's Avatar
actually thats right about where I was hoping for. I have LTs, ORY, stock cat back/cutout, lid,
LS1 intake, 9" rear w/ 3.89 gears, stock pulley, stock heads
the intake is holding me back, and the 9" also creates loss, the important part is that Ill be able to launch good at the track w/o worrying (once I get some good slicks). honestly I care more about track numbers than dyno numbers
One other thing... Did I see you put oil in the rocker bolt bosses? Maybe youre hydolocking those bolts and thats why your preload is off....
I put a dab of oil on the top of the valve stem, and on the top of the pushrod, to add some lubrication on first startup. (i also dipped the pushrods in oil for the lifter area)
I also have a small exhaust leak on the drivers side somewhere, maybe that was part of the noise
Old 07-02-2005, 09:09 PM
Roarin_8's Avatar
DO IT!!!
Easy for you to say, I just don't have the time. TTP will get it done for me though.
Old 07-10-2005, 05:14 PM
PunkNPonys's Avatar
I was wondering the same thing. This cam in a six-speed should put down 390rwhp easy. I am not trying to **** anyone off. Do you have ported TB? I am thinking about getting the same cam but now i am scared mine is going in a auto car too.
Old 07-10-2005, 05:43 PM
150shotWS6's Avatar
How long did that take you guys to install it? Awesome vids and car..... That one TA was very fast though!
Old 07-10-2005, 05:45 PM
BigBlockChev572's Avatar
Awesome Vids!
Old 07-10-2005, 07:22 PM
Tech's Avatar
Not too shabby. Piston slap is a bitch.
