HELP!!! problem after rebuild
Old 07-02-2005, 11:48 PM
cgworth's Avatar
Default HELP!!! problem after rebuild
I just rebuilt my LS1 and reused my crank, rods, and pistons everthing else was new, including heads and cam. the heads are milled .36 i am using a tsp 228 and 7.35 pushrods. I am also using the weiland aluminum intake and asp underdrive pulley.i also went to TR6 plugs where i was using tr55's i have also tried 3 differant tunes none of wich changed the sypmtoms. also i went ahead and rebuilt the engine while i had it out just for reasons of freshingit up. there was no mechanical reason to the rebuild.
not sure if it matters but i went to a 3200 stall also
It is fine at idle and fine if i take off at WOT and is fine all the way througheach gear as long as i am at WOT but if I let off or take off normal and just crusie or lightly accelerate i get little pops (backfires) out the exhaust, and it will not kickdown at WOT once it does this. I have to come to a complete stop and take off again to be able to accelerate hard again. im sure its detecting knock and ang cutting timeing but why? also if i am crusing on the highway at say around 65 my rpms are low but it surges the whole time and i cannot get on it.
i have an HP tuners log file if anyone would like to take a look at it and maybe help me figure it out.
Old 07-03-2005, 07:34 AM
cgworth's Avatar
ttt..
Old 07-03-2005, 08:14 AM
98A4LS1's Avatar
Sure, send me the data you logged.
Old 07-04-2005, 10:42 PM
cgworth's Avatar
I just thought of something else. This car was a 95 firebird with a 3.4L annd i transplanted a 98 Ls1 in her but didnt change the fuelpump. i had the wiring harness worked and used a custom fuel rail with a return line and regulator built in so i wouldnt have to drop the tank or change guages. Does this sound like a fueling problem?
Old 07-05-2005, 10:55 AM
chino_man279's Avatar
Try putting a fuel pressure guage on it....this might not be your problem right now, but a 10 year old pump meant for a 3.4 probably is not going to last to long regardless feeding a 400 horse V8
Old 07-08-2005, 08:49 AM
cgworth's Avatar
ttt..
