Best cam for AFR 205's
Best cam for AFR 205's?
What cam is making the best rwhp from the AFR 205's? And can you put 225's in the 346 with a big cam to gain more rwhp than the 205's? Or are the heads too big? I asked because I read an article about some guys who ported the 205's to 228 and put them on a stock 346, and ran it with a 299/307 cam in the stock 346! They had to put bigger valve covers on I would think, but still, that don't sound smart to me!!!
Maybe you had better give us some more details about what your goal is???
Originally Posted by SideStep
Are you saying you care only for MAX peak rwhp??? If so get a "big" high 23x/24x cam with XE-R type lobes, no advance and a 114 LSA... LG, TSP, AFR, etc... can give you recommendations...
here's a nice little blueprint to go by. vinci's PROJECT AFR 03 corvette convertible. made 403/394 before the converter and gear change and with a smaller cam than what you have now.
the vehicle page
http://www.vincihighperformance.com/...CT%20PAGE.HTML
here's the graphs page
http://www.vincihighperformance.com/...20PAGE%20.HTML
the vehicle page
(818)890-0616
Regards,
Tony
6600 rpm clutch dump of death Administrator
A 3734 XE-R lobe is 248 @ .050 and is 297 @ .006. So, that cam is big, but perhaps not as big as it sounds...
As for the 205's. The simple answer is it depends on how tight you want to spin the motor. That will determine how much duration, etc... you want. You can always add more duration, but if you have more than you need, you simply slow down airflow.
As for the 225's I think you'd definitely pick up peak power. As for the gains over 205's, it all depends on what you want to do.
Important considerations are
Weight
Gearing
RPM range
Compression, etc....
see sig for my setup. i was going to go with the 225's milled to 66cc, but the valves were too big. even with flycut pistons, there wasn't enough p\v clearence
Originally Posted by Phil99vette
- 4 degrees of seperation from intake to exhaust
- Cam duration will determine power band
1) 224/228 112 + 2 would be nice with 11.1:1 CR
2) 234/238 111 + 0 would be nice with 12.0:1 CR
Phil
Phil
I've been thinking about these heads myself, but my current cam is a reverse split, the old X1 230/227. Would I be better off with a different cam for good midrange hp < 6,600 rpms with those 205 heads?
Can always go custom cam like I did - had to fill out a sheet with 40 questions on it ( what do I plan to do, header primary size, intake etc. ) but I think it was well worth it.
227/231 571/578 111 intake no advance with 1.8 gold quick lifts it's now at 605/612 at 11:1 compression
Just saw your post above - 4 degrees seperation again!
Originally Posted by jub jub
The cam in my sig was recommended by Tony. The power is there and it's very streetable!
Hey what head gasket did you use??? Would/Could you post a dyno, I am interested in the TQ line???
my set up-01 ws6 m6,346ci,afr 205 heads 59cc 0.40 cometic gasket,LG motorsports-g5x3 cam,kooks w/off roads,b&b tryflo catback,asp pulley,12bolt w/4.11's. i have a stock ls6 intake,stock th-body and stock mass air(all will change soon)i made 425hp and 390tq on a mustang dyno. with lsx 90mm combo and a 85 mass i'm sure it will climb to 450-455ish hp.my car is stock weight and ran a best of 11.21@122.27 on a clutch thay went out this day on my 2nd run. goodluck to ya on finding a cam.
Originally Posted by Tony Mamo @ AFR
Give me a call @ AFR when you have some time....I will go over all your questions and try to advise you on the best route to take. Some decisions lead to other situations you might not have considered. I can help you put a real nice package together that will help you achieve your goals (hopefully!)
(818)890-0616
Regards,
Tony
(818)890-0616
Regards,
Tony
Originally Posted by J-Rod
I suspect those were gross numbers (.006) often called "advertised numbers rather than lift @ .050.
Weight
Gearing
RPM range
Weight
Gearing
RPM range
with a 150 shot I guarantee a 10.1 to 10.4 range .
In short words GO FOR THE G5X4 , if it is not your daily use ............
