Small water leak after cam install...
I got my cam installed over the weekend and everything is great except I am getting a little bit of anti-freeze on the carport after the car sits a while. No over temp problems and I can't even see that the radiator has lost any coolant. I did see a little drop come out of the right side of the water pump where it mates to the block after I watched it at idle for over 15 minutes. Seems to drip more after the car is turned off. I torqued the bolts as directed, 11lbs and then to 22lbs. Any ideas? I did reuse the gaskets being the car is a 99 and I was told I could do that. Thanks.
Originally Posted by Y2K SS
You can reuse the gaskets if they look good. Not all the time you can reuse them. I'll bet theres your problem.
Originally Posted by BOONE
Mine leaked with new gaskets on the right side, i just torqued to 25 lbs and it stopped.
