Can i use Crane Dual valvespring with stock retainers ?
The steel Crane retainer is a fine choice, Ti retainers compromise affordability and some amount of strength. For the extra 300 or so RPM peak, is it worth it??
I went with their steel retainer, and spent some of the leftover $$ on upgraded Manley locks. Still had enough $$ left in the diff between steel and titanium retainers to fill the tank a time or two...
Originally Posted by fast98
ya but why you you replace the locks? is there a known problem with stock ones.......no there isnt.
If you're trying to connect a <$15 cost diff (GM locks versus aftermarket) to a $125 cost diff (Ti versus steel retainers) in some effort to argue with me, you're reaching just a bit there sparky.
and titanium is not weaker the steel. i might not know the exact strength qualites of both but ti has been used for a long time with high revs and high spring pressures.
Unless you know exactly which alloy is being used in both the Ti and steel pieces, or you're willing to fund some failure mode testing, it's impossible to support what you've stated.
its worth the money
How exactly is that a good investment?
For someone like myself, who has experienced valve float issues in the past, the titanium retainers were worth every penny of their cost. Even if you don't have a problem with valve float, lightening your valvetrain components is never a bad thing.
Originally Posted by XTrooper
Your statement that titanium retainers compromise some degree of strength is no more supported than the argument that they don't. That said, the fact is there's no need for fast98 or anyone else to conduct any "failure mode testing" on them as titanium retainers have been thoroughly tested and proven for the years they've now been in use.
These were in road course conditions, 20+mins of continuous WOT/lift/WOT engine service. Maybe a tad more demanding than 12sec of drag racing.
I understand that two cases doesn't support a statistically-valid conclusion. However with both involving Ti retainers failing, and zero cases of steel ones doing it, this makes me uncomfortable with their durability.
So it's another case of picking the right part for the right application and the right wallet size.
Originally Posted by Unaffiliated Racing
Consumer grade? Wether it's Dale jr. or Warren johnson..they get the same Ti material you would.
Well I think since I work for Comp Cams, it would be considered fact.
