You Guessed It, Cams?
I AM STARTING TO PUT MY 393 TOGETHER AND I WANT TO TRY TO HIT THE 450 RWHP MARK IF I CAN BUT I CAN'T DECIDE ON A CAM IS THE RE ANY HELP OUT THERE? I HAVE BEEN TOLD TO GO WITH THE GX5-2 ANY COMMENTS ON IT? oR MAYBE F-14? I DON'T KNOW I JUST WANT TO SEE IF I CAN GET ANY HELP IN THIS AREA.
I AM GOING TO RUN THAT VICTOR JR CARB SETUP WITH 750
11.0 TO 1 COM.
STOCK HEADS PORT/POLISH 918 SPRINGS
ELECTRIC W/P
AND THE MOTOR WILL ONLY BE TURNING AN ALT.
700R4 W/ 32-3600 LOCKUP CONVERTER
11.0 TO 1 COM.
ELECTRIC W/P
Its impossible to say or even ballpark since your changing so much. Depending on how agressive you go with heads, cam, intake and the rest of the boltons, a 39x cid motor might make anywhere from 450 - 550 RWHP. Less if its an auto with a high stall converter.
EDIT: Sorry I thought the thread starter was asking about HP gains
Originally Posted by 89lx-ls1
I talked to alan he recommended a custom cam- 243/250 617/630 on a 112+2 or 4.
How does that sound guys. And thanks for highjacking my thread there Scrappy.
Alan knows what he is doing. I wouldn't second guess his recommendation without a lot more knowledge than I (or you) posess.
You could always contact other sponsors and see what they recommend.
You will need a better spring than 918's. One of the associated duals (such as PRC's) would be a cheap and recently popular choice. Or comp 921's...
