i could use some advice
Old 07-15-2005, 03:08 PM
DAVID98Z's Avatar
Default i could use some advice
im in the middle of ordering my head and cam package and i would like it if u guys let me know if theres nething else i should be ordering so far the package consists of
Precision Race Components Stage 2.5 5.3L Cylinder Heads,Texas Speed & Performance Custom-Grind 233/239 R.2 Camshaft: 233/239, .600"/.605", 113 LSA, Texas Speed & Performance Chromemoly 7.40" Pushrods, Rollmaster Double-Roller Non-Heat-Treated LS1/LS6 Timing Set, Standard Bearing Texas Speed & Performance Modified LS6 Oil Pump, Basic GM Heads & Cam Kit: Head Bolts, Head Gaskets, Timing Cover Gasket, Front Crankshaft Seal, Balancer Bolt, Water Pump Gaskets 160* thermostat and under drive pulleys
sorry for the long post,any advice would be appreciated
Old 07-15-2005, 03:45 PM
conan's Avatar
sounds good to me the only thing you might want to upgrade is to arp head bolts. Have fun with your new power.
Old 07-15-2005, 04:23 PM
DAVID98Z's Avatar
thanks alot man,i also am trying to get an ls6 intake from this board but am having a hard time finding one i will also be doing a fuddle tc an 3.73 gears any gues on how much power i might make?
Old 07-15-2005, 05:59 PM
conan's Avatar
Definetly get the ls6 intake and get it before the H/C swap so you dont have to do it twice. Power You should be in the 410-425rwhp range.
https://ls1tech.com/forums/sponsor-sales-specials/351007-cheapest-place-get-ls6-intake.html
Old 07-15-2005, 06:08 PM
DAVID98Z's Avatar
https://ls1tech.com/forums/showthread.php?t=351007
thanks for the input and website,and those are the numbers im looking for
Old 07-18-2005, 07:33 AM
DAVID98Z's Avatar
t t t
