Big power in an A4
Old 07-17-2005, 02:38 PM
GoFast908Z's Avatar
Default Big power in an A4
Ok, I've done some research and know a little of my options. This is where I have some questions.
Here is what I'm looking for:
-STOCK displacement LS1
-no Forced Ind, no juice
-no HUGE nasty cam
-Street driveable and reliable - this is the key
-475 rwhp @ 20% driveline loss works to ~ 600 flywheel hp.
Here is what I will be doing in preparation:
-high strength aluminum driveshaft
-Stage 2 4L60E (600hp, 650 ftlbs) from cmotorsports.com
-Vig 3000 stall
-tranny cooler
-suspension to handle the power
-Rearend......???
Here are my questions:
1. With that much power, can i beef up the stock 10 bolt? : with (30, 31, 33? spline axles), tougher limited slip, TA cover (also want to go with 3.42:1 gears)
2. With Stage 2 heads, a moderate cam, excellent tuning, will that achieve the 475 i'm looking for?
3. If not, will forged internals: pistons, crankshaft (if there are any), balancing and blueprinting the engine get the power i'm looking for?
4. If I can't use a beefed up rear end, what rear end should I get? I have a BMR adj. torque arm, that can't work with a 12 bolt, so what would i need to get that would work.
PS. I'm not setting a price limit here. Well....under $10k.
Old 07-17-2005, 02:57 PM
ApacheDrill's Avatar
Those are some big questions and some strong opinions that go with them. It can be done easily for 10K or less.. I will give u some food for thought to help u out a little. If you do heads and cam, dont forget the headers,exhaust and intake.. How streetable do u want the car? The rear end is a must with bigger numbers.. either 9" or 12 bolt ( debatible on what is better), its not worth the money to beef up a 10 bolt.. I personally went with a TH 350, i dont believe there is a bullet proof 4l60E. The biggest thing is to decide exactley what u want to do and come up with a plan. Thats way your doing it right the 1st time and not back tracking. Take into consideration cam size, stall and gear ratio..Good Luck and have fun. Its a long journey and it never ends..
Old 07-17-2005, 03:02 PM
blue2000Z28's Avatar
Well with as big of a cam as your going to need, I would go with a 4000+ converter. Also, there are packages out there. Talk to Matt at TTp. They have one hell of a package. TSP and Thunder are also great when it comes to this stuff. ------> just look at the sponcers....Ohhh yeah, and there IS no built proof tranny(4L60E) If i were you, I would go to a TH350/400. Now your losing OD but they do make OD kits for it...it is just an arm and a leg i believe. But good luck
Old 07-17-2005, 03:07 PM
mikemodano9c's Avatar
what you want is almost impossible...
w/o a huge cam it isn't likely to happen in a 346 ls1...look around...the huge nasty heads/cam cars sometimes get near (maybe a couple have eclipsed 500rw) that mark...and those are m6 cars...nothing like an a4 when comparing numbers. what you are right about is that it will take some serious flywheel hp in an auto to get 475rw.
if you can get 400-450 unlocked through a 4l60e with a big stall you are already doing pretty good...even that usually takes a pretty decent size cam and good heads...
if you are really looking to hit 475 N/A in an auto you should be looking at a 408 not a 346...
you want to make 550+flywheel in a 346 ls1 with a moderate size cam...not easy
Old 07-17-2005, 04:46 PM
XTrooper's Avatar
Sorry, but there's no frigging way you're going to get 475 rwhp out of a stock-displacement A4 car without using either a "HUGE nasty cam" or a power adder (FI or NO2). One or the other is EXACTLY what you're going to need to make anything near what you're hoping for.
Old 07-17-2005, 05:34 PM
blkZ28spt's Avatar
I agree, do not count on getting 475 rwhp out of a small cammed NA 346. You could probably get 430-450 without too much trouble. Larger cam (not huge), AFR's, 90mm LSX/TB combo and all bolt-ons.
For the cam, Maybe something like the MS3 (237/242 .603/.609 113) or G5X3/4. IMO it's about as large as you can go and be totally streetable for a daily driver.
Old 07-18-2005, 12:40 AM
JZ'sTA's Avatar
I agree.
Be happy to get 430 with a Very top notch set of heads, 11.0 or better compression, a cam that is in the low 230 duration area or bigger, fast 90/90 combo, Tune, and all other boltons.
Converter is also too small
Old 07-18-2005, 10:26 AM
Ed Curtis's Avatar
Cool
Originally Posted by JZ'sTA
I agree.
Go to LS1GTO.com and check out "Bone" and his mods...
435 RWHP, small cam, AFR heads and a it's a DD...
Ed
Old 07-18-2005, 11:18 AM
MUSTANGEATER's Avatar
Not to spark some huge discussion on driveline loss but I don't think you'll need 600 @ the crank to do 475 to the rear wheels in an A4, especially with a 10 bolt and a lockup converter.
600 HP @ the crank out of a 346 = 1.73 HP per Cube should be done easily. Now with your requirements of No Big Nasty Cam, and "Reliable" are all subjective to your own personal preference.
Old 07-18-2005, 02:54 PM
GoFast908Z's Avatar
Ed
It's an M6 and that kind of power is much easier than in an Auto.
Old 07-18-2005, 04:20 PM
XTrooper's Avatar
Ed
Umm.........
It's an M6 car.
Old 07-18-2005, 04:25 PM
Ed
yah that's a solid 400-410rw in an auto w/stall...
that motor would only have to make another 125hp to meet this guys desires...
Old 07-18-2005, 04:29 PM
Ed Curtis's Avatar
Exclamation
Does the engine know what's behind it????
Using similar pieces will net the same gains in performance.
This is why I hate all this chassis dyno crap. People get all hung up on a "peak" figure. The power levels this GTO combo made are easily duplicated with an automatic. With the correct torque converter, it'll be even faster than the M6 he's got, let alone it's going into an F-body...
Ed
Old 07-18-2005, 04:30 PM
blkZ28spt's Avatar
My A4 with 4k stall makes 385 rwhp cam only. If you were to add 60 rwhp between heads and 90mm LSX intake (very plausible) it would be at 445 rwhp. Given that, and dynos I've seen, I'd say 430-450 rwhp in a NA 346 through an unlocked high stall converter, while retaining daily drivability, should be possible. I'll know for myself eventually.
Old 07-18-2005, 04:34 PM
Ed
i've never heard of of a 346 A4 hit 475rw with any hydraulic cam...i've seen some people hit in the 440-450rw range in an A4...which would be right around that 475rw mark this guy is looking to get...unfortunately these are all cars with BIG cams, and it sounds like this guy wants something tame from his first post.
Old 07-18-2005, 04:35 PM
GoFast908Z's Avatar
Hey, I'm just trying to find out what I can and can't do. I've never really seen super high numbers out of an A4, so I want to know what CAN be done. As I learn more, I'm adjusting my "requirements" See my new thread.
Old 07-18-2005, 04:42 PM
i looked at your graph...i see your using a ms3 237/242 .603/.609 113...a pretty healthy cam
the graph looks locked to me, if im wrong please let me know...unlocked you would probably only be at around 370-375rw...
im not shitting on your numbers by any means, all we are trying to say is that 475 through an A4 locked or unlocked isn't gonna be easy, and is more a stretch than anything no matter what mods you do...
im sure with some good heads like some afr's and a 90/90, etc. you will see your projected 440~450 numbers...that's about as good as it's gonna get through an A4 @ 346 cubes with a hydraulic cam...
Old 07-18-2005, 04:45 PM
XTrooper's Avatar
Ed
No one is arguing that performance would be as good or better. Hell, we all know that. The problem is that wasn't the stated goal of the poster and that wasn't his question. He stated he wanted to make a streetable 475 rwhp in his A4 car, period.
Your example doesn't fit the bill and your argument is the wrong one.
Old 07-18-2005, 05:04 PM
blkZ28spt's Avatar
I seriously wonder about my dyno. People have told me it looks locked to them, I myself don't really know what to think, and Larry at LS1 speed was almost positive that it was done unlocked. So.... It does only trap 113, although it is an A4 and I do expect that to pick up when fall comes around. I ran the 11.92 @ 112.8 in June.
Old 07-18-2005, 07:01 PM
Ed Curtis's Avatar
Exclamation
My response was to back up what JZ stated. That's why I quoted "his" post...
475 streetable with the "small" cam criteria in not possible. Bone's streetable package was more in line with the 430 spec that JZ alluded to...
My bad for agreeing with the majority.
I guess next time I'll tell him to run a set of Stage 7.25 ported LS-9.75 heads with a Magic-Rex-X7 camshaft and a super-douper twenty disc lockup torque converter to make 1000 RWHP on a Cyclotronic Model LSD chassis dyno.
Then we can race each other by taping our dyno sheets to the side windows...
Heads-up "Pro Street Dyno" racing at its best!
Wait! I can't race with him since I only have my "Super Street Flow Bench" license.
Ed
