Stock block...resleeve, bore, or go to dart?
Old 07-18-2005, 02:42 AM
2000_LS1's Avatar
Default Stock block...resleeve, bore, or go to dart?
I cracked 2 pistons, 7 and 8, while spraying the stock motor. Scared the walls about .027" and I have since bought the 408. I have some extra AFR 225's, may be looking to go with a TT or SC FI set-up so I'll need to stay at a lower compression. Then the 408 would probably make a good swap into an S-10 or something with the NX 300 DP going in. Just a thought but I am looking into the following options and some may or may not even be achievable.
Resleeving the block and going with a 383 or 370 is the first thing that crossed my mind. It's a good set-up from what I hear and read and proven itself.
Boring the block. I am not sure that this can be done on the ls1, but has anyone tried it? I've heard and read .015" is the limit but why???
Third, my machinist says he heard of the Dart sleeves making it into a 427. I haven't heard of anyone using this set-up, why? Not that popular, not strong, too expensive what is the deal with this set-up or is it for ls6 blocks only? I didn't think that there was a difference but I'm sure someone on here knows.
Oh yea, the last would be resleeving to stock and keeping the 408 in. This way I have the factory motor for use at a later date. I'm not too fond of this one but hey, it is an option.
Which would you guys recommend? Would love more info on the 427...doing a search revealed nothing for an LS1, just SBC...thanks.
Old 07-18-2005, 03:10 AM
jrp
SN95 Director
jrp's Avatar
its the MID darton sleeves you are referring to and quite a few people are running them. check the FAQ in my sig for more info.
Old 07-18-2005, 03:15 AM
2000_LS1's Avatar
Looking now, thanks.
Old 07-18-2005, 03:23 AM
2000_LS1's Avatar
Damn jrp, how in the hell did you get all of that info??? BTW, thanks, your faq will provide alot of reading material for now until I'm 60. Nice conglomeration of info here! Thanks alot though, loks all three questions will be answered
Old 07-18-2005, 03:30 AM
jrp
SN95 Director
jrp's Avatar
here and there
if you decide on the darton block i would only have it done by Steve Demirjian or Howard Wolf.
Old 07-18-2005, 03:43 AM
2000_LS1's Avatar
Where are they at? Your FAQ may say but I haven't read it all yet.
How would this work out as far as finding pistons? I haven't checked yet (still reading) but can/could you get pistons for use with a P/A i.e. TT or N2O? Assuming just any 4.125 piston would work.
Also, SpeedInc has the blocks for $2400 would you say that is a fair price or would having it done be cheaper and more reliable? I am just wondering about the cost. Would $4500 be a safe figure on a shortblock?
Old 07-18-2005, 07:35 AM
Squintz Palladoris's Avatar
From others expierience this is good advise.
Brad
Old 07-18-2005, 11:50 AM
2000_LS1's Avatar
Where are they at?
Old 07-18-2005, 01:59 PM
send a PM to him. Username is; Steve - Race Eng
Brad
Old 07-18-2005, 02:04 PM
2000_LS1's Avatar
thanks
Old 09-13-2005, 05:50 PM
52172's Avatar
what is howard wolfs 10-20?
Old 09-19-2005, 09:32 PM
2000_LS1's Avatar
Old 09-19-2005, 09:44 PM
52172's Avatar
10-20= location
Old 09-21-2005, 12:05 PM
blind527's Avatar
CAN you bore an LS1? I heard you can only resleeve it?
Old 09-21-2005, 12:09 PM
777's Avatar
You cannot bore an ls1 due to the thin walls.
Old 09-21-2005, 12:11 PM
blind527's Avatar
Didn't think so. I knew this kid is full of **** when he said he bored his LS1 vette 30 over. Thanks
Old 09-21-2005, 12:30 PM
ArcticZ28's Avatar
You can lightly hone it (say for a 383 rotating assembly), but anything further requires resleeve.
Old 09-21-2005, 01:26 PM
bulletLS1's Avatar
the newer blocks you can overbore .10 and the earlier blocks you can only hone to about .040, you can resleeve all blocks
Old 09-21-2005, 05:44 PM
Camaro99SS's Avatar
The highest you can go on the newer LS1's is .020". The earlier blocks can't go past .005". The only small block that could probably tolerate .10" is a high nickel 327 block of the 60's and early 350's.
Jason
Old 09-21-2005, 08:35 PM
jrp
SN95 Director
jrp's Avatar
it can be done, just the sleeve integrity is compromised IMO to not even be worth building upon. the stock iron liners are ~.060 thick.
