most cali leagal power w/ MTI stage 2E heads
i have a chance to get a good deal on a set of MTI stage 2E heads. if anyone has been following my delema, i wanted to go with AFR 205s and a CheaTR cam, but funds may not allow that. so my questions are:
1) Will the 2Es match well with a TR 224/ 114 on shortie headers?
2) Will the 2Es match well with a CheaTR cam on shortie headers?
3) which combo would make more power with an ls6 intake (w/EGR), March underdrive pullies, a ported TB and SLP maf?
4) will these heads pass the visual inspection/ do they have stock casting #s?
thanks for your help guys.
I've never heard of anybody failing a visual because the casting numbers didn't match up on the heads. That would take one hellova thurough smog tech.
I don't have the technical know-how to give you a full answer, but good luck. I'm curious too, as I may go with the same set of heads if you get the green light from this bunch.
