Which cam is better for 10:7-11:1 Compression?
14 Second Truck Club
Which cam is better for 10:7-11:1 Compression and why?
218/218-112
218/218-113
218/220-112
218/220-113
218/222-112
218/222-113
Thanks!
218/218-112
218/218-113
218/220-112
218/220-113
218/222-112
218/222-113
Thanks!
Originally Posted by rons 00z
N/A, turbo, nitrous, supercharger, cubes, headflow, did i miss anything else?
Stock cube LS1, N/A, Patriot Performance Stage 2 5.3 heads (I think they flow around 296-300cfm @.600)...
Actually it is the opposite. A higher SCR will help a bigger split.
But really you should find which of the cams you mentionned that has the best DCR (Dynamic Compression Ratio) and use that one.
