B1 vs. LS6 (Z06) cam ?
Old 07-21-2005, 07:53 PM
Hawk312's Avatar
Default B1 vs. LS6 (Z06) cam ?
I am considering one of these two cams. I have a chance for a very good deal on both. Here are the specs on the two cams:
B1:
221 / 221 .558 / .558 114 LSA
LS6 (Z06):
207 / 218 .553 / .553 117 LSA (from memory)
I know the B1 will be a little louder and have a little more lope to it. I know both will work with the 02+ LS6 springs. I was originally going to go with the LS6, but I am just wondering what kind of #`s you guys are seeing at the track with the B1. I know I`ve seen people post -.4 tenths and plus 3-4mph in the quarter, and +30 rwhp on the dyno for 01-02 cars with the LS6 cam, which is decent considering the price and the fact that gas mileage and driveablity will be the same. How about the B1? What kind of gains are you guys seeing with this? How much has your gas mileage been affected? Is the lope noticeable? I want to be as stealth as possible. I have the LT4 HOT cam in my `hawk, and I consider that a "screamer". I will be installing long tubes with a catted y. Will the cam be unnoticeable as far as sound? I am going to leave the stock heads untouched, and will eventually get a tune. Will it drive without a tune?
I have already ruled out the LPE cam because of it`s higher lift and steeper ramp rates (valvetrain dependability is a concern).
Thanks.
Old 07-21-2005, 08:01 PM
00T\A's Avatar
The B-1 is great.
I have no track times yet,but i make 392 rwhp cam only.
It fun on the street
Old 07-21-2005, 08:03 PM
Hawk312's Avatar
Originally Posted by 00T\A
The B-1 is great.
And you have a 2000!!! What other mods do you have?
Old 07-21-2005, 08:14 PM
00T\A's Avatar
all supporting boltons & LS6 intake.
Old 07-21-2005, 08:30 PM
Hawk312's Avatar
Pulley? LT`s w/o cats? Cat-back? MAF? Throttle body? 1.8 Rocker arms?
Would you say that the cam is responsible for about 40rwhp? How is the sound? Would people suspect a cam with a catted y and a decent cat-back thats not overbearing?
Thanks.
Old 07-21-2005, 09:00 PM
glennster's Avatar
I have a B-1 in my car with most all the bolt-ons and it surpassed all my expectations.I've considered a bigger cam but I'm afraid to lose the absolutely flat torque peak and how hard the car pulls.I give the clutch a quick slip,net high 1.7's and get into the 11's with it,thats off the street.I may try an F11 and see what happens,if I lose low end torque the B-1 goes back in.
Old 07-21-2005, 09:11 PM
Hawk312's Avatar
Do both of you have a full exhaust? Pullies? LS6 intakes? Just trying to get an idea.
Old 07-21-2005, 09:26 PM
00T\A's Avatar
Thanks.
All you said with with cats stock maf stock rockers.
an yes i would say around 30 to 35 rwhp from that cam.
an it doe's have a noticeble lope
Old 07-21-2005, 09:29 PM
glennster's Avatar
SLP lid,pulley,LS6 intake,kooks lt's w/ORY,magnaflow catback w/18" bullet,ported t-body.M/T drag radials,moser 12 bolt w/4.10's,Ram stage 4 clutch w/billet fly,a few BMR suspension pieces and no weight reduction.Peeps with knowledge will know it has a cam.
Old 07-21-2005, 09:35 PM
blkbird's Avatar
What springs did you all use for the B-1 cam?
00T\A's Avatar
I have beem seriosly thinking about the F-13 myself,but dayum the b-1 is so much fun on the street with no issues what so ever.
Dude those numbers are sick
Old 07-21-2005, 09:39 PM
00T\A's Avatar
I 'am running the comp 918's.
Old 07-21-2005, 09:41 PM
blkbird's Avatar
I have a set of brand new 04 LS6 springs and wondering if those will work.
Old 07-21-2005, 09:44 PM
00T\A's Avatar
Not sure on that one,I would be scared to try them.
Old 07-21-2005, 10:11 PM
Hawk312's Avatar
I posted the specs for both cams in the first post. The lift is only .005" higher and the duration is almost identical (218 vs. 221) for the B1 cam. I would say that profile is close enough to the LS6 cam that you should be able to use the LS6 springs IMO. Remember, the LS6 springs and cam were installed as OEM parts in a mass produced vehicle in which 100,000 miles should be easily attainable.
Old 07-21-2005, 10:14 PM
Hawk312's Avatar
I`m not sure guys. With all the mods you guys have, I wouldnt think there would be much difference between the B1 and the Z06, plus I would be *completely* stealth and not have any real effect on gas mileage. What do you guys think?
Is it worth an extra 5rwhp or so to give that up? Decisions......
Old 07-21-2005, 10:21 PM
Ryan02SS's Avatar
B1 all the way over the LS6 cam. This is coming from someone who has ran the LS6 cam before. It was simply weak under 4500rpms. From 4500-6500rpms it pulled damn hard for what it was, but the B1 will outpower the LS6 cam from idle to 6500rpms.
I would not run LS6 springs w the B1 if it was my motor. Taking too much chance. I've heard of LS6 springs breaking with guys Autocrossing their stock Z06's. Get a set of C918's and you'll be sitting happy.
Old 07-21-2005, 10:23 PM
00T\A's Avatar
I think your would get the best of both worlds with the b1.
But the ZO6 would no doubt have a better steath effect.
Old 07-21-2005, 10:33 PM
Hawk312's Avatar
How is the B1 up top? Is it similar to the Z06? This in itself is a tough decision for me, as low end torque might not be what I need or want more of. I mean, I already have traction problems at the track, and when you are racing, you really dont spend much time at all below 4000rpm anyway. Plus, I would imagine if you are making more power down low, it is going to have more of a negative effect on my gas mileage which is important to me since I drive 100 miles a day. But it would be more fun around town if it is a big difference.
Wouldn`t the 918`s mean more spring pressure, which means more wear on the other valvetrain components and higher risk of the already "at risk" pushrods? I mean, the Z06 cam is very close to the B1, and I don`t plan on autocrossing where you spend extended amounts of time in the upper RPM range.
Old 07-22-2005, 07:44 AM
AFTICA's Avatar
The B-1 has taken me into the 11's with a mild converter. (See sig) Looking back at the timeslips it looks like I gained about 4 tenths and 4.5 mph with it. When I first put it in my car would not idle without tuning. It does have a lope to it but you can just raise the idle a bit to get rid of it. Gas mileage took a hit...how much I don't know because I don't care. lol I switched to 918 springs when I did the cam. I bought the B-1 because many of the other aggressive cams at the time were causing loud valvetrain noise, which with my quiet exhaust would have bothered me. The B-1 has no valvetrain noise whatsoever.
