6.0L with a G5X2?
Old 07-25-2005, 06:40 PM
8banger's Avatar
Default 6.0L with a G5X2?
Hey everyone. I'm throwing a G5X2 in my car within the next month and will probably run cam-only for a while. I'd like to, within the next year or two, get a 6.0L LQ9 iron block and go from there. What I was thinking is run the stock rotating assembly with a .030 overbore, and see how that works. I'll be getting ported heads sometime between now and then, and the biggest question would be the cam. How would the G5X2 work in a 6.0 bored .030 over? I want to make some big power without losing too much in the low end, so should I go with a bigger cam? What kind of specs would you recommend? Also, could a 4L60E handle it for long, or should I get a TH350? Please help. Thanks.
Adam
Old 07-25-2005, 10:31 PM
Gold Z's Avatar
I have over 20,000 miles on a .030 overbored 6.0 liter iron block with the G5-X2 cam. It makes plenty of horsepower on or off the spray. I'm using a Rock-On 4L60E. It is my daily driver. The last time out she was running 6.7s.
Old 07-26-2005, 02:19 AM
8banger's Avatar
Nice. Any dynos or pictures?
Old 07-26-2005, 04:58 AM
Ben01C5's Avatar
I have the G5X-2 in my car with AFR heads and am totally happy with it.
I think you will be fine.
Old 07-26-2005, 08:56 AM
~JOSHUA's Avatar
Does anyone know the specs of the G5X2? Duration? Thanks
Old 07-26-2005, 09:58 AM
PREDATOR-Z's Avatar
G5-X2-112 G5X2 232/240 Duration & 595/608 Lift at 112 Lobe Seperation.
G5-X2-114 G5X2 232/240 Duration & 595/608 Lift at 114 Lobe Seperation.
Old 07-26-2005, 10:56 AM
~JOSHUA's Avatar
Thanks bro!!! A friend has this cam and he couldn't find the specs. I'll let him know.
Old 07-26-2005, 11:08 AM
ArcticZ28's Avatar
A G5x2 will be nothing for a 6.0. If anything you can run much bigger. I'm running a .060 bore with a 244/248 cam and it loves it.
Old 07-26-2005, 06:41 PM
Gold Z's Avatar
You wanted a pic.......dyno is in the sig.
Old 07-26-2005, 07:14 PM
ArcticZ28's Avatar
Gold Z, those dyno numbers gotta be on the juice! What are your mods?
Old 07-26-2005, 11:31 PM
8banger's Avatar
Yeah, what's it throwin down naturally aspirated?
Old 07-27-2005, 12:28 AM
Gold Z's Avatar
432 is the best NA dyno. The engine has Lunati pro mod rods and diamond pistons, ported LS6 heads, Yella Terra rockers, Crane lifters, G5-X2 cam, ARP head studs, and all the other goodies that go with a pro built motor. A dual stage NX MAF kit jumps the horsepiwer to 638. I'm using a Rock-On 4L60E tranny with a vig convertor and a Ford 9" rearend.
Old 07-27-2005, 02:39 AM
ArcticZ28's Avatar
Not bad NA numbers man... that dual stage kit really help out with putting that power to the ground?
Old 07-27-2005, 03:00 AM
Gold Z's Avatar
The nitrous system helps tremendously. Right now I'm running 100 hp jetting in both stages for a total of 200 hp. I can hit the first stage much sooner on the street without breaking the tires loose than I could with a single 200 shot. Then I can bring in the second stage if I need it.
