Gaskets and part numbers, are these correct?
Getting ready to order all the parts and gaskets I need to do my oil pump/EGR delete/LS6 intake install.
12562267 Oil sending unit
12557752 Oil Pump O-ring
12559271 Water pump gaskets (2)
12574294 Front timing cover gasket
12553617 AIR tube gaskets for air block off plates
12561244 Front engine crank seal
Also need, new crank bolt, new SLP oil pump, fuel line removal tool from autozone.
Anything else?
Anything else?
12557752 - Oil Pump O-Ring 5/pk
12559271 - Water Pump Gaskets
12574294 - Frt Cover Gasket
12585673 - Crank Seal
12557840 - Crank Bolt
12586665 - Oil Pump
I would purchase an Oil Pump from the dealer. Cost me 75.82. Porting has been known to be a little over-rated. Just my 2 cents.
Hope that helps.
Dave
12586665 - Oil Pump
Hope that helps.
Dave
12586665 - Oil Pump
Hope that helps.
Dave
12586665 - Oil Pump
Hope that helps.
Dave
Thanks
12585673 Front engine crank seal
Ordered all of the above from GMPartsDirect today for ~$80 shipped.
Also orderd the re-usable ARP balancer bolt from Thunder Racing.
Just need to order the SLP oil pump and 160 degree thermostat from LM Performance tomorrow.
