Attention all California people. Advise on biggest cam I can go and pass smog.
Hey all:
I live in California with the strict smog laws. I have all the bolt ons LT headers and H/C with a great tune and pass the sniffer with no problems.
It wont pass visual but it passed the sniffer with no problem.
I have the 224/224 570 lift with 114 lsa.
I keep hearing I have alot more room for more power with a bigger cam and that mine is a very small cam.
Can I go bigger and still pass smog. Or would it even be worth it? Thanks
Originally Posted by jrp
honesty though with what you've got i wouldnt even bother with a swap, especially if you want to stay 100% legal.
what kinda heads are you running?
SN95 Director
BTW, i've seen your threads in the regional forum. honestly i'd go with a set of AFR 205's and follow Tony's recipe: milled .024 and .040 cometic. i'd have the cam degree'd if it wasnt during initial install, retune, and enjoy.
i havent heard enough of DLA's head quality to make a judgment either way. if your still looking at them i'd find out who does there CNC if they outsouce, who does the finall install and valve job, port volumes and full valve lift flow.
Also I apperciate it when you post you opinion on my sites. Thanks
Originally Posted by Ferocity02
224/224 is pretty much the largest you want to get. Mine passed, but it was close. I'd look for power in other places if you are worried about passing smog.
SN95 Director
well then i'd install the TEA's, tune, and see how you make out. you might not even want a new cam if the power is satisfactory. obviously properly setup the bigger cam will make more power but your just decreasing your chances of passing emissions legitly.
not sure if you followed the thread about smog in the regional forum but i'll state the same thing here. with the available combinations (patrick G and vortech come to mind) its gettinng to the point where huge cams, LT's, ORY's arent needed to make over 400rwhp in a completely 100% smog legal route.
LS1 Tech Administrator
The key point to staying emissions legal seems to be keeping your overlap at .006" at or under 46 degrees. Thunder Racing has just developed a new cam call the CheaTR 2 that's designed to be the most powerful emissions legal cam on the market. Check out these specs:
227/227 .639/,639 116LSA 113ICL.
This cam has great valve events for making power everywhere and best of all, the overlap is only 45 degrees at .006! This cam will work best with long tube headers and ported heads. Regardless, you'll want some good springs! I might even try it next!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I have come to the resolve that I will probably just have to buy a stock motor and swap it every two years. My Vette' wont be ready till next summer (2 year ground up project), but I know it will never pass. Nothing worse than a hot rod you cant drive.
Bah, run whatever cam you want. I'd suggest the TSP 233/239 and get a tune. When it comes to passing smog, just add methanol to the tank.
Seriously, with quite a few people in California running big cams with high compression motors and true duals, there are ways of getting around the smog ****'s.
Jason
Jason
