ok to take rod caps off???????
Old 07-29-2005, 01:33 PM
redbandit98's Avatar
Default ok to take rod caps off???????
hey,,i want to check out my rod bearings and see how they look with the motor out..is it ok to take off the rod caps 1 at a time,inspect them and torque them back down to spec? will this be ok to do without any special kind of clearance checking etc...? thanks matt
EDIT: i forgot to mention...i do know that the rod bolts are TTY i was just wondering about if i had to measure anything..
thanks again
Old 07-29-2005, 01:44 PM
PREDATOR-Z's Avatar
If you take them off, you have to change bolts. The best are Katech
Old 07-29-2005, 01:51 PM
yes i was aware of the bolts being tty..i was just wondering if i had to do anything special besides just put it back on and torque it down..i think i have a spun bearing but am not for sure..just want to check them out..
matt
Old 07-29-2005, 02:53 PM
PREDATOR-Z's Avatar
No, just make sure they go back on the way they came out.
