Patriot LS6 Stage2 heads+Patriot 226/226 .585"/.585" LSA 112, RWHP ?
How much RWHP to expect from this H/C combo with full bolt ons like filter , headers ..., in a 99 M6 camaro .
I remember in CHP magazine Dec 04 issue there was a test with the same heads and cam with LS6 intake and 1.7 rockers , the engine itself made 502 HP and 459 lb-ft and they got 522 HP and 466 lb-ft with Fast LSX intake manifold and 78mm throttle body , looking at these numbers I think the RWHP should be more !
LS1 Tech Administrator
410-420 rwhp seems to be what that combo is bringing these days.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Can we consider that this combo is as good as AFR 205 + 224/228 LSA 114 cam ?
I think the numbers are close if i am not wrong .
the AFR's are a completely aftermarket design cylinder head, where while unique in some ways the Patriot LS6 style heads are a GM casting that has been highly modified by the guys at Patriot. Lots of differences between the two heads and they both have a pros and cons(so to speak).
The AFR's in an equal setup will usually put down more power than the Patriots on the low end due to smaller port volumes, but for some guys the AFR's are too expensive(the pros and cons I mentioned).
Don't get too caught up in dyno numbers, dynos are a tool for tuning and to compare gains or losses when modifing a car.
The two combos you mention would probably be close on the same dyno.
If you want give Brad at call at 866-571-3347 and discuss this with him.
The AFRs with the AFR cam is a proven combination. Most cars running it make 440-480 rwhp. Most PP cars seem to be down about 20 rwhp in comparison (based on countless dynos from board members).
__________________
