Perimeter Heads To Center Bolt
Old 07-31-2005, 03:19 PM
zapp168's Avatar
Default Perimeter Heads To Center Bolt
Anybody run into this? I am putting Patriot heads on my 1998 T/A I have the perimeter style valve covers, I got a pair of ceterbolt valve covers however on the passenger side cover I am short one vent tube off the valve cover. I am probably going to just use a "T" connector instead of drilling the cover and attaching the other tube, just wondering if anyone else has run into this and what their solution was.
Thanks
Old 07-31-2005, 03:22 PM
Derek98z's Avatar
I did this. I did some creative engineering with stuff I had in the garage to make it work.
Also, the 98 coil packs did not bolt up to the tray very well for me. I might have bought a shatty tray, it was used. So I had to use bolts and screws to hold them on.
Old 08-01-2005, 01:57 AM
Redneck Z's Avatar
I used some fuel line and connectors from NAPA. It's not to hard of a rig, just be creative.
Old 08-01-2005, 11:21 AM
zapp168's Avatar
So did you basically hook it into the front fitting?
