when u go above 7000 rpm !! check the PIX
Old 08-01-2005, 01:34 AM
FiveSevenEagle's Avatar
Default when u go above 7000 rpm !! check the PIX
G5X3 + patriot stage 2 ..... and when reached 7,400 rpm KABOOOM .. and here is the pix ...
we r lucky here in saudi arabia we have the ls1 every where so we took a short block from the junk yard for $ 420 .. lol
this is happened a week ago and we r driving the car now with new shortblock and stock heads ,,
patriot heads had some scratches near the valves ,, i think we still can use them ill take my time polishing them .. if not ill send them to the nearest pepsi factory so they can recycle them to a cans
please guys tell me if u need more pix for the heads or for the broken block .. just tell me what angel u want me to take the pic from ..
P.S the late engine was on a 2001 z28 ,
Attached Thumbnails when u go above 7000 rpm !! check the PIX-20050726-003-.jpg   when u go above 7000 rpm !! check the PIX-20050726-008-.jpg   when u go above 7000 rpm !! check the PIX-20050730.jpg   when u go above 7000 rpm !! check the PIX-20050726-005-.jpg
Old 08-01-2005, 01:49 AM
98Grnz28's Avatar
Must be nice to get a good shortblock for 400.00. That sucks about the blow up. Must have broke a rod bolt.
Old 08-01-2005, 01:52 AM
1QuickT-A's Avatar
Damn! That looks familiar.. My old LT1 did that! lol
Why were you spinning the motor to 7400 rpms!!!!
Old 08-01-2005, 01:54 AM
DONAIMIAN's Avatar
takes some bawls to spin the stock bottom end over 7200.
Old 08-01-2005, 01:59 AM
engine is giving steady power until the 7500 rpm with G5X3 ,
we were racing a modded ZR1 LT5 ... and we wanted to give the max , we wanted to teach him a lesson lool , we wanted to have the longest distance we can ,
it was a non nitrous race thats why we hit it to the limit ,
Old 08-01-2005, 02:00 AM
98Grnz28's Avatar
They must be a high roller. I can't afford to blow engine up.
Old 08-01-2005, 02:01 AM
thats right !
ill try to post the hptuner record ,
Old 08-01-2005, 02:03 AM
we were using stock lifters lool ..
ill try to take the g5x3 out of the broken block and do some pictures ,
Old 08-01-2005, 03:35 AM
am not sure if we still can use this cam (g5x3) .. maybe some polishing will solve the problem ?
Attached Thumbnails when u go above 7000 rpm !! check the PIX-20050801-002-.jpg   when u go above 7000 rpm !! check the PIX-20050801-001-.jpg   when u go above 7000 rpm !! check the PIX-20050801-011-.jpg   when u go above 7000 rpm !! check the PIX-20050801-008-.jpg   when u go above 7000 rpm !! check the PIX-20050801-011-.jpg
Old 08-01-2005, 07:55 AM
JoeyGC5's Avatar
DAMN! I'd say that cam has seen it's last days
Old 08-01-2005, 08:05 AM
Ric
Ric's Avatar
OUCH.
On a side note, how much would shipping be on an LS1 from Saudi Arabia to the US???
Old 08-01-2005, 08:09 AM
777's Avatar
More than what it would cost to get a decent block here.
Old 08-01-2005, 08:31 AM
GuitsBoy's Avatar
I would not use that cam again. Tolerances have to be much tighter than a head for instance, which means you wont be able to polish it accurately.
Old 08-01-2005, 08:33 AM
xfactor_pitbulls's Avatar
Nothing a little Jb Weld couldnt fix! Yeah you guys sure did a number on that one.
Brandon
Old 08-01-2005, 09:06 AM
moeZ28's Avatar
or you can just send them to me since you dont care about them and i will take care of them. they would look real good on my car.
Old 08-02-2005, 01:52 AM
Default patriot heads pix , CAN I REUSE IT !!
these r the pix of the patriot heads , am not sure if we can reuse it ,,,,, please comment on it ,
Attached Thumbnails when u go above 7000 rpm !! check the PIX-20050801-016-.jpg   when u go above 7000 rpm !! check the PIX-20050801-017-.jpg   when u go above 7000 rpm !! check the PIX-20050801-019-.jpg   when u go above 7000 rpm !! check the PIX-20050801-020-.jpg   when u go above 7000 rpm !! check the PIX-20050801-021-.jpg
Old 08-02-2005, 02:07 AM
Originally Posted by Ric
OUCH.
i dont know how much it will cost u if u want to ship from saudi arabia but i know it costs 2 much .. for instance when we bought the heads it cost us 500 + dollars to bring it here ! and when we shipped the rear end ( MOSER ) it cost us almost 1000 dollars ,
i really envy u guys , i wish i can go back there
P.S i was raised in the states , greele colorado , and my brother was born there and i used to go there every summer but after the 9/11 thing everything turned upside down ,
Old 08-02-2005, 02:14 AM
98Grnz28's Avatar
Is that piston ring hanging out from the valve? I would say that the heads are still good with alot of work. Me personally I would trash them.
Old 08-02-2005, 02:23 AM
hehe yeah this is the piston ring , if u observed the block pictures the crack ( hole ) is at the site of piston 6 .. where this piston ring coming from ,
i would do the same .. TRASH them .. but my partner wants to give it a try ,
he is a compression addict , he wants to mill them ...
Old 08-02-2005, 02:29 AM
98Grnz28's Avatar
Hey go for good luck with them.
