Will 4.010" pistons work for a 408ci motor?
Originally Posted by ls1290
The classic version of a 408 CID LS1 is 4.030" bore and 4.000" stroke. 4.010" bore pistons will not work with a 4.030" bore block. If you go with a 4.010" bore piston and 4.00" stroke crank, you will get 404 CID.
Keith
Keith
I agree.
If you get a new block they can match the block to the pistons.
A lot of extra work if you already have a 4.030 bore done.
Originally Posted by v8maro
Well there was a great deal on some diamond ones with coating for $400, thought i'd look into it.
That is a good deal, where did you see it I may be interested if local.
Matt
http://pg.photos.yahoo.com/ph/apengi...c9.jpg&.src=ph
http://pg.photos.yahoo.com/ph/apengi...b1.jpg&.src=ph
Matt, I'm sure if you want them Brian(from motown) can take care of you. these were from the APE haul.
-Steve
-Steve
