Which cam to go with?????????????
Moderator
I will be picking my HOSS up this coming weekend and will be going with the AFR heads 205's or 225's and just using the stock shortblock for now. What cam should I go with using these heads? I want street manners as well but I want something that perform's very well in hp's numbers 450+...Its a 6sp car...
My last car was a ball's out drag race car but I just want to calm down this time on this car and stay street only!!!!
Thanks for the info!!!!!
The usuals would be the F13/F14 from Futral, 233/239 REV2 from TSP, G5x2 from LG, etc... Should be able to make 430+ with any of those cams rather easily and still have good street manners. Lots of choices out there. But, the Search button is your friend.
Moderator
What is the highest achieved horse power cam on the streets now days that is streetable?
Who else? I would rather not fly cut the pistons for this application....
I did a install last week with a set of Absolute Speed stage 2.5 LS6 heads and a 234/238 595/602 114+4 cam fast 90/90 SLP LT's, 19"rims and tires, and it made 470 in are hot nasty *** weather in Fla.
We did flycut the pistons and mill the heas .040 for added compression and ran a .045 gasket. The results were nice, but can be done with a better head and smaller cam.
Look into the 224/228 cam Tony from AFR used on his corvette that made 480.
I doubt you will achieve those numbers but 450 can defentially be made using that cam. You wont have to flycut, your driveability will be awsome and you might even get lucky and get away with stock injectors but dont count on it.
Man are you in luck, we are going to be installing on a box stock 02 SS M6(13K babied miles) the following combo, TR CHEATER cam,AFR205's,Pacesetter LT's with ORY pipe and a 90/90 intake setup,tuning to be done by Mike at GMMG. Baseline stock HP to be done tommorow night, the install is this weekend Sat/Sunday. Will post up asap after the tune
Moderator
Great, I'm finally going to keep this beauty on the street, I look forward to the AFR heads and a small cam, 90/90mm and kooks SS straight tubes 1 7/8", custom Y and corsa exaust...
The cam is the main obective with the above setup....
Keep the options coming....
Badz,
AFR 205, cometic .040, mill 60cc and AFR 224/228 cam # 6016 0n a 114+1
You'll get the 430 for sure if degreed and professionaly tuned.
PM Tony Mamo (he made over 480 with his set up), so 430 shouldn't be too hard.
No flycut.
https://ls1tech.com/forums/showthrea...&highlight=AFR
No flycut.
LS1 Tech Administrator
Jeff,
My setup is pretty close to what you want. Very streetable and still running cats and y-pipe with excellent ground clearance. See details the the signature.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
