Best motor oil
Old 08-11-2005, 11:43 AM
afdude402's Avatar
Default Best motor oil
what is the best oil that you guys run in your ls1 cars, i was thinking of using royal purple any other suggestions
Old 08-11-2005, 11:50 AM
2001CamaroGuy's Avatar
I have always just used Mobil 1............never had any problems.....
Old 08-11-2005, 12:36 PM
99BlkLs1's Avatar
Mobile 1
Old 08-11-2005, 01:04 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
If you will do a search on this forum, you will find several threads with more text than the US Constitution on the favorite oils used by site users. And, Mobil 1, Royal Purple, Castrol, and others are popular here.
Old 08-11-2005, 01:20 PM
windshear's Avatar
I use Mobil 1 5W-30. Changed from Mobil 10W-30 non synthetic at 8800 miles.
Old 08-11-2005, 02:27 PM
it's the internet.....nobody knows how to use the "search" button.....
Old 08-11-2005, 02:30 PM
gollum's Avatar
And nobody knows good oil from bad oil. MOBILE 1 5W30 hear
Old 08-11-2005, 02:40 PM
Tranzor's Avatar
I use Amsoil XL 5w30, changed twice a year... once before drag race season, and once after.
Old 08-11-2005, 08:42 PM
krexken's Avatar
Wal Mart Super Tech 10-30. Burns as good as any other.
Old 08-11-2005, 09:06 PM
Mud
Mud's Avatar
Also with the Wal-Mart Super Tech you get a brand new Super Tech filter for only 89 cents!!!!!!!!!!!!
Old 08-11-2005, 09:42 PM
Import Patrol
CrawlinWS6's Avatar
mobil 1 here, used valvoline once and the tick got louder.
Old 08-11-2005, 09:45 PM
blkZ28spt's Avatar
It's called a search button. Seriously.
Mobil 1 0w40 here.
Old 08-11-2005, 09:50 PM
1 BLOWN V8's Avatar
Mobil 1 here also
Old 08-11-2005, 10:01 PM
firefighter's Avatar
I've been using Valvoline for almost 20 years no reason to change now. Been using the Syn Power stuff for almost 10 with no problems. The last truck was sold with 210K and burned no oil and got 20mpg on the highway doin 80mph not bad for a 4.3L in a brick shaped Blazer. Oh and I change the oil every 5K.
Old 08-11-2005, 10:22 PM
shooter's Avatar
Mobil 1 5W-30 is the best for LS-1!!!!
Old 08-11-2005, 10:25 PM
blkZ28spt's Avatar
Care to tell us why that is your opinion?
Old 08-11-2005, 10:31 PM
gollum's Avatar
I once read Leginfelter uses Mobile1 10w30 in their modified cars.
Old 08-11-2005, 11:36 PM
Redneck Z's Avatar
Patman say's oil analysis has shown german castrol 0w30 to be the best.
Old 08-12-2005, 12:25 AM
JRracing's Avatar
Mobil 1 10w30 here also.
Old 08-12-2005, 12:27 AM
lsx24's Avatar
You know here's my 2c:
Moving to synthetic, if you use a true synthetic, you should have better luck. That's what I did last oil change although my particular choices were derived from existing stock rather than first preference. I used what they had, and luckily they had the good stuff.
However, when (if?) the Big Guns come out, they gravitate towards a 'cleaner' of the synthetics, such as Castrol, Redline, or Mobil, all of which are flying Mighty high in the ls1 community, because of the various oil analyis seen. Though neither have spotless results.
In the short term the transition is not as important; both consistant oil changes and proper material choices are equally as huge. Obviously synthetics will normally run longer without needing an oil change (from what I hear). However, as a consumer it's virtually impossible to predict the oil change interval beforehand (even with thicker synthetics), without comparitive oil anaylsis done on each car during 'normal' driving conditions.
The result is, the printout is comprised of a percentage of various metals and contaminents, and an overall 'condition' analysis of the blend. This is what counts, although it doesn't hurt to analyze specific components. Afterwhich, the change interval, as well as the viscostiy and/or brand of oil can be modified, for both synthetic or blends, which as I said before can be very different from goals to goals, car to car, and budget to budget.
Quick Reply: Best motor oil
