Gold .650s vs Comp 918s....
How do these compare? One is a straight spring, the other is conical...which is better?
I'm not worried about breaking a single spring, what I want to know is which one is more stable at higher rpms?
Weight is an issue, and I cant imagine the Golds with a Ti retaier are lighter than the 918s with a stock retainer.
Input??
Input??
Depends on the cam.
Smaller cam, go with the 918's.
When it comes to weight....they Patriot's are MAYBE a pound heavier total kit.
I have both a set of 918's and a set of the PP duals in Ziplock bags. Very close in weight.
Originally Posted by Brian@CompCams
Valvetrain weight is important down to the gram....much less a pound! As far as stability and harmonics goes..that 918 will walk off and leave a dual in the dust!
Originally Posted by 99ssleeper
Wow...this is some good info!
Yes, valvetrain mass is impostant down to the gram. I like the fact that the Golds are duals...but I'm not betting the Comps would break with my cam (.588").
Noiser?....What thinking lead you to that? When we are talking about weight on valvetrain..we aren't talking about slowing your car down becaue you added a pound here or there. Valvetrain weight is important down to the gram....much less a pound! As far as stability and harmonics goes..that 918 will walk off and leave a dual in the dust!
Brian,
Can the #26120 Single Beehive spring (155lb.@ 1.88" and 377lb.@ 1.28" be adapted to work w/ lobes beyond the 918's limits by machining spring pockets, ect.?
Originally Posted by Ferocity02
My Comp 918's floated my valves after 12k miles with stock retainers. They have been replaced with Patriot Gold duals and Ti retainers. Cam is a TR 224/224 114.
Originally Posted by PREDATOR-Z
All you had to do is shim them
I'd rather not beat around the bush. They got some good time in. I am much happier with my Golds now. The power doesnt fall off at 5500 and the valvetrain noise has not increased as some said it would.
