<<<BEST LS1 CAM?>>>
Old 08-15-2005, 01:20 PM
s.o.m.SS's Avatar
Default <<<BEST LS1 CAM?>>>
i have a 2002 ss, 6speed full suspension, 12 bolt... ect... whats the best cam for it? i want bad *** results, but nothing like the HPE 610/612 lift cam... its my daily driver and i dont know what to go with! i need to know ASAP! thanks
Old 08-15-2005, 01:35 PM
777's Avatar
Man seriously do a search. There are so many what's the best ls1 cam threads out there. First and foremost, there is no BEST OVERALL CAM cam's are specific to your goals. You can have a big power house and crappy driveability or you can have in between or whatever. I'd suggest you search and see what you want. Most popular cams are tr224 (thunder racing) Futral Motorsports f-13, f-14 (I like these cams), G5X3, just find something you want. Come with a more specific question once you narrow it down.
This will help you tremendously. That is why it is a sticky. Read them all.
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old 08-15-2005, 02:14 PM
s.o.m.SS's Avatar
cool thanks, im just looking for overall. its a daily driver, but i dont want a weak cam you know...
Old 08-15-2005, 02:23 PM
777's Avatar
I'd get the F-13 then if I were you. It is a great daily driver all around cam that will make a pretty good amount of power. Cam only with the usual bolt-ons (headers, intake, exhaust, etc.) you should be around 385-400rwhp.
Old 08-15-2005, 04:13 PM
s.o.m.SS's Avatar
thanks, any one else?
Old 08-15-2005, 05:16 PM
blkZ28spt's Avatar
SEARCH!
These posts are seriously rediculous.
Your best bet is to SEARCH and read the cam guide sticky at the top of this forum.
Make sure you have full exhaust (headers), then grab something like a TR224, F13, G5X2, TSP 233/239, etc etc.
Old 08-15-2005, 06:14 PM
s.o.m.SS's Avatar
okay, daily drive, full suspension, 12 bolt rear, 6 speed, hooker super comp headers, ls6 intake, 3inch off-road y pip w/ a cut out/ slp exhaust... now thats what i have and for the cam???
Old 08-15-2005, 06:15 PM
s.o.m.SS's Avatar
okay, daily drive, full suspension, 12 bolt rear, 6 speed, hooker super comp headers, ls6 intake, 3inch off-road y pipe w/ a cut out/ slp exhaust... now thats what i have and for the cam??? and like i said at the top, nothing huge like a 610/612 hpe s cam... there its narrowed down and i need a profession opinion
Old 08-15-2005, 06:23 PM
2001 White Ws6's Avatar
Read the CAM GUIDE that is stickied up at the top of this forum.
Old 08-15-2005, 06:55 PM
s.o.m.SS's Avatar
okay.... i have read, and printed out the thread... all im doing is asking for any one elses opinion... like ive said thanks
Old 08-15-2005, 07:24 PM
blkZ28spt's Avatar
When you say you don't want a "huge cam", are you looking at the lifts, durations, overlap...? If you are looking at lifts, why do you care if it has high lift?
Old 08-15-2005, 07:32 PM
s.o.m.SS's Avatar
o my god, okay something around 585 lift, not 612... simple read the post... not tryin to be a dick but ive said what im lookin for
Old 08-15-2005, 07:43 PM
blkZ28spt's Avatar
Well, the problem is that what you are looking for is open to interpretation. We could easily recommend anything from a hotcam or LS6 to a G5X3.
Again, why are you setting lift requirements? When it comes to drivabilty you won't notice different lifts at all. IMO setting a somewhat arbitrary lift limit won't help you much.
So you are looking for a max power, out of a daily driver cam that doesn't have more than .585 lift? I'll get back to you on that in a few mins here...most cams of any decent size have more lift than that.
Edit: Most of the popular cams that make good power have more than .585 lift, so that will limit your choices a good bit. No F13, no G5X2 or X3, no 233/239....that leaves it at a 224. Can't really go wrong with a TR224, after all.
Old 08-15-2005, 07:54 PM
lsx24's Avatar
Alright what I think is its going to be inaccurate to estimate based on many variables, but at the same time not several options such that there are no tech solutions, okay.
For instance with stock gears and a six speed, and assuming its not a daily driver but rather a bracket racer, a F13 may indeed be right for you. OTOH, if it is a daily driver and you do lots of roll-ons in mid gear, something like a TR224 (or even the milder TR220) would be a safer bet, maybe even a wiser choice. See what I mean?
What are some of your planned mods and can you tell us what the car is used for, that might give us a better idea of the overall package. In addition if you can describe what characteristics you would like to see in a cam that would help to isolate the options. That way we can see that combining the information in the cam guide, and inter weaving the data from the goals you're after, estimations can be made about the size.
Old 08-15-2005, 07:57 PM
lsx24's Avatar
Ha Ha two almost symetrical replies; how often does that happen
Old 08-15-2005, 08:01 PM
s.o.m.SS's Avatar
sorry forgot to mention its has 3:73 gears and underdrive pulleys... its a daily driver and i want to get the most hp possible... but not have some insane *** cam... i dont know near as much as you all do... so that is why im posting this.. sorry for the confusion i just want to get the right cam...
Old 08-15-2005, 08:08 PM
blkZ28spt's Avatar
Okay, listen to me: Ignore the lifts. Don't even worry about them. What you want to worry about is overlap as it is what determines idle quality. You can calculate overlap with this formula:
[(intake duration + exhaust duration) /4] - LSA, and finally multiplied by two. Most common measurements and what you see on here are at .05" lift. A TR224 on a 112 lsa has 0* at .05 and smaller cams have negative overlap (negative meaning how far from having overlap it is). On the other end of the spectrum a T-rex has nearly 25* at .05. My MS3 has 13.5*. I think you would be best served with an overlap in the area of 10* or less, give or take.
There are other things that affect idle quality, but overlap is the most siginifcant. If you can get the duration numbers at other intervals it can tell you even more. Remember that the key to good street manners with larger cams is a GOOD TUNE.
Seriously consider an F13, G5X2 or similer. Do a lot of searches (seriously, search can REALLY help you) and also see if there is somebody in your area (or multiples) with cams that you can listen to and observe idle quality/drivability first hand..
Old 08-15-2005, 08:09 PM
KCFormula's Avatar
Best = Trex
Old 08-15-2005, 08:10 PM
ulySSes's Avatar
blkZ28spt and 98t56ta already mentioned some good cams. Why don't you start some research by searching under the ones they mentioned? There is plenty of info on them.
Old 08-15-2005, 08:11 PM
jrp
SN95 Director
jrp's Avatar
put in the GM grand am cam, its only got .570 liift......
Quick Reply: <<<BEST LS1 CAM?>>>
