whats this? pic
Old 08-16-2005, 12:41 PM
narc's Avatar
Default whats this? pic
whats this hole that is on the front passanger side valve cover that is threraded and looks like it something should be in it? did i lose something? it looks like its open to the valve cover?
http://i14.photobucket.com/albums/a3...8/P1010437.jpg
Old 08-16-2005, 12:46 PM
Super Moderator
Reckless's Avatar
just an extra bolt boss, no sweat
blkZ28spt's Avatar
You aren't missing anything. If you worry about it being open to the valve cover, get in close and have a look. Or try poking something through it. You'll find out for sure that way.
Old 08-16-2005, 01:01 PM
narc's Avatar
thanks guys. im going to spry down my engine w simple green then spray over everything with a hose with the "shower" nozzle.. then leaf blow her. sound safe? any precautions?
Old 08-16-2005, 01:05 PM
blkZ28spt's Avatar
Not safe. I suggest using a hand held spray bottle and have a nice rag/towel in hand. Some things under the hood don't really like to get wet.
Old 08-16-2005, 01:08 PM
kpowr82's Avatar
Free flowing stream of water from a hose is your best bet if you wanna use the hose. Turn the water on about a 1/4 of the way, just enough to get a steady stream of water. Use only as much water as you need to. Cover the PCM, drive belts and fuse box with foil. Then you can go to town.
I think there is an engine detailing sticky in the appearance forum.
Old 08-16-2005, 01:10 PM
blkZ28spt's Avatar
I believe you are correct.
Check that out, it would be your best resource.
Old 08-16-2005, 01:33 PM
Super Moderator
Reckless's Avatar
I have used power washers on the engines time and time again with no issues. Just don't want to get too close to wiring with really high pressure. But to each his own
Old 08-16-2005, 01:41 PM
blkZ28spt's Avatar
Yes, if you know what you are doing and are carefull you can do that. But just to be safe I don't like to recommend a stream of flowing water to wash the engine. Speaking of which, mine too could REALLY use some freshening up.....
Old 08-16-2005, 01:48 PM
narc's Avatar
ya i have been reading in that forum but i get mixed messages. its like 50% of guys say "no you will screw the KS and electrical prob. etc.." and the other 50% are like "i use a power washer everyweek and go to town on it..no problem" so i am a bit confused.
i was going to use some Solder Seal GUNK foamy engine brite (which is a spray foam) and spray liberally to the valve cover and front of block as well as LS6 intake..then wash with a light stream of water .. then blow dry w leaf blower, then start up and drive for 20 min to dry rest. bad idea?
Gunk or simple green if so?
Old 08-16-2005, 01:51 PM
blkZ28spt's Avatar
I like simple green, myself. Havn't tried anything else though.
Old 08-16-2005, 01:53 PM
JustAnIlluzion's Avatar
u need some LTs in there
Old 08-16-2005, 02:04 PM
Brandon Boomhauer's Avatar
I spray the cleaner on, then use a mitt to clean, scrub, then rinse with low stream of water. Toothbrush, etc, on the front of the block infront of the head, and other small places. Never have covered anything up, but im carefull about where I spray water..
Old 08-16-2005, 02:05 PM
Jaspirr's Avatar
As has been said already, make sure you don't get under the intake and hit the knock sensors with any water. Could cost you a couple hundred bucks.
Old 08-16-2005, 02:12 PM
narc's Avatar
anyone got a pic of where that KS is?
i plan on spraying the gunk foam on the valve covers (even though it is corrosive it wont hurt my coil packs will it?) and on front of block and then simple grren on intake manifold. then rinse. alright
Old 08-16-2005, 03:21 PM
ArcticZ28's Avatar
Knock Sensor is under your intake, you're not gonna get anything down in there unless you aim a power washer where the intake seals to the block. Simple Green says it corrodes aluminum so I'm not too much a fan of it. I'd use what is recommended in the sticky for washing your engine.
Old 08-16-2005, 03:43 PM
narc's Avatar
umm the sticky recommends simple green
Old 08-16-2005, 07:21 PM
Grimes's Avatar
used simple green here. sprayed it on, and let it sit for 10 minutes, then sprayed the bay down with a hose on medium. I stayed away from the pcm and the fuse boxes. No problems, and the bay looks great!
Old 08-16-2005, 08:09 PM
Shu
Shu's Avatar
I've used simple green and a hose and it works like magic. Then I just run the engine to dry it. Still have to get into some spots with a rag. Good luck.
Old 08-17-2005, 12:15 AM
ArcticZ28's Avatar
Use it if you want, others have with no problem. However, straight from the simple green consumer site..
"Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation."
Not saying you can't use it, I just don't think it's worth it when there are other less corrosive ways to clean. But, to each their own. Just giving a heads up that not too many realize.
