Cam timing advance
Old 08-16-2005, 04:06 PM
arctic2kss's Avatar
Default Cam timing advance
Is is recommended to add timing advance in the cam if I am putting a new one in? Say 2 to 3 degrees?
Old 08-16-2005, 04:09 PM
Ryan02SS's Avatar
Really depends on your overall goals of the powerband and how the cam was ground from the factory. Most LS1 grinds seem to already have +2 or +4 degrees advance ground in negating the need to further advance the cam. What cam are you planning on using?
Old 08-16-2005, 04:21 PM
arctic2kss's Avatar
comp 224/224 .567 114 LSA
