Local guy claiming 487 through an A4. Is this BS?
Old 08-17-2005, 07:20 PM
Kenny H's Avatar
Default Local guy claiming 487 through an A4. Is this BS?
This is his quote, "I have the magic stick for a cam, Partiot 6.0 heads buillet crank flat top flycut pistions by Diamond 6.0 block,1 7/8"supermaxx long tubes, with ORY and Borla back, Evl 3 trans Yank SS 4000 stall 3.73 gears and why not just a 275 shot ogf the go go juice. But no I didn't spray the Zo6. The car makes 487 to the wheels unlocked on motor alone with 110 fuel"
Does this sound possible? This car is from Stateville NC and its a white WS6 with purple/blue flames on it supposedly. Does anyone know of the car?
Old 08-17-2005, 07:30 PM
1FST99Z's Avatar
Anything is possible. but why not call him out and have him dyno it. or show you his dyno sheet. if he knows he makes 487 w/o spray then he had to dyno it sometime.
Beast96Z's Avatar
It's probablly a 408 ci motor. The numbers sound rather high, but anything is possible. If he had a better set of heads, I'd say maybe, but with the ones he has, it's just not likley.
Old 08-17-2005, 07:35 PM
Kenny H's Avatar
Isn't a 4000 stall a bit big for 487 RWHP AND a 275 shot?
Old 08-17-2005, 10:51 PM
JZ'sTA's Avatar
Defentially possible especially with the fuel being ran.
If he has a very aggressive cam and a good amount of compression I wouldn't raise the BS flag.
Old 08-17-2005, 11:16 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Jason@TSP's 408ci engine did 480rwhp through a unlocked 3800 stall A4 and 780rwhp on the juice. I guess it depends on the displacement/compression whether or not this particular one is BS.
Old 08-18-2005, 12:36 PM
SDB
SDB's Avatar
unless it is a 408 with real good heads, it is NOT making 487 rwhp with the converter unlocked. If it is a stock shortblock as it seems to be, he is full of ****.
Old 08-18-2005, 12:44 PM
6 Second Club Moderator
LASTLS1's Avatar
Agree!
Old 08-18-2005, 01:48 PM
The Juggernaut's Avatar
ummm.. why would you think a 12:1 408 couldn't make 487 unlocked on a dyno jet?
I mean,hell, he put a 4l60e in a ZO6.
Old 08-18-2005, 02:04 PM
777's Avatar
That's what I'm saying. VINCE has a 408 putting out 550rwhp through a m6 so I don't see why an auto couldn't put out 487rwhp.
Old 08-19-2005, 01:05 AM
SDB
SDB's Avatar
because you will loose at least another 5-7% with the 4L60E, so 550 would be more like 500, and an unlocked high stall converter can kill 30-40 hp easily. I was assuming this was stock cube. If it is a 408 with AFR 225 and a huge cam, it might just make 487 unlocked, but I would still be somewhat skeptical.
SDB
Old 08-19-2005, 08:17 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I agree. He is using the Partiot 6.0 paper weights, I mean heads.
Keith
Old 08-19-2005, 09:03 AM
WS6snake-eater's Avatar
I don't see why not...I made 448rwhp through a built 4l60e, with a pye 3600 stall on a nitrous tune, with et streets at 22psi and a 3.73 gear, stock cubes. This guy has a 6.0 block (stroked?) and a pretty radical cam. It's not unbelievable that with a high compression setup, and a lot of timing (racefuel) that it can't be done.
Old 08-19-2005, 10:15 AM
JS
JS's Avatar
I made 430RW and it went 10.80's@124 threw an A4
I believe w/more Comp./Cam and Head I mightve got to 460RW but 490RW,no way....
