5.3L heads???
5.3L heads???
Whats the story with these? What motor are they stock for? Why are people putting them on LS1's? Do they lower compression ratio? whats the internal numbers on these heads?
I am totally confused about why these heads benefit these engines.
Any help is appreciated.
They are from a 5.3L Gen III engine. they come in cars from GTP's to trucks. They have smaller combustion chambers and raise the compression about 1/2 a point. Internal # are the same as regular LS1 heads except the intake valve is 1.88 or something and the ls1 has a 2.0 intake valve. There is a thread somewhere that depicts all of the different head castings and the differences in them.....search is your friend, and will likely keep people from beating you down
