NGK TR55 plug gapping results
I've always kept the gaps @ .59 as they came in the boxes. My friend said I should put them down to .45 so I did. My mileage got worse and the car would idle rougher on a cold start and there's more surge under 1,800rpm. To top it off it would always intermittantly throw a SES light. The code is for the map sensor.
Yesterday I put the gap back to .59 and ALL the problems went away.
Just thought I would share.
To go to .045, you're better off using a TR5 as it comes gapped at .039.
Identical plug to the TR55, just colder. The plug mfg. don't recommend bending more than +/- 10.
However, I hear what your saying.
I however did put in TR5's at .045 for this new motor and it seems to like them just fine. I'm also at 11:1 compression; perhasp that's the difference?
