View Poll Results: Which is better for noise level and protection for LS1 piston slap
Amsoil 5W40 euro.
41
48.81%
German Made Castrol Syn. 0W30
43
51.19%
Voters: 84. You may not vote on this poll
Poll. Amsoil vs. castrol syntec
Old 08-20-2005, 01:16 PM
narc's Avatar
Question Poll. Amsoil vs. castrol syntec
Although i have heard that both Amsoil 5W40 euro. and german made Castrol Syntec 0W30 (M0501) are great oils and that they help reduce piston slap noise i would like to have a poll on which you prefer. I have a bad case of piston slap and i would like to know what you all think is better for it and its noise.
I quess im asking which is better for protection and noise level on a motor with piston slap
1 = Amsoil
2 = Castrol
Old 08-20-2005, 03:09 PM
JayLS1-327's Avatar
I'm really happy with my Amsoil system 2000 0W-30. It's quiet, and consumption is down. I have not run an analysis.
https://www.amsoil.com/storefront/tso.aspx
Old 08-20-2005, 08:26 PM
tirefryer's Avatar
My piston slap was really noticable on cold starts and warm restarts with the GC 0W30. I just switched last weekend to the Amsoil 5W40 and on cold start the piston slap is almost totally gone. It is very slight. On warm restarts it is stil noticable but does not do it as long as the GC did. I would highly recomend switching to the Amsoil 5W40 to quiet the motor, plus it has a higher HTHS of 4.2 which will protect better when you are beeting on her.
Old 08-21-2005, 12:21 AM
seabirdak's Avatar
Come on now Amsoil all the way, it's been proven... but whats up with all the funky number weights?
Old 08-21-2005, 12:59 AM
00T\A's Avatar
No brainer Amsoil
Old 08-21-2005, 09:20 AM
mr2guru's Avatar
Amsoil>*
Old 08-21-2005, 08:26 PM
TJ
TJ's Avatar
i voted castrol, its what i use in my Z.
good things about 5w40 mobil 1. i use it in my HD. changed over from havoline dino oil and there is absolutely no valvetrain noise on startup, or piston slap on my 6.0.
i think i will be using the 5w40 mobil 1 in the car if i cant find the 0w30 castrol.
Old 08-21-2005, 10:13 PM
narc's Avatar
sounds like amsoil 5W40 is the way to go huh..where can i find it and how many qts are you guys running (5.5?)
Old 08-22-2005, 10:00 AM
narc's Avatar
i figure id run 6 qts of amsoil 5(or 10?which one?)W40 and a longer Acdelco PF-49 filter
sound right? now where to get Amsoil? can i get it locally?
Old 08-22-2005, 03:27 PM
tirefryer's Avatar
You can get it from the sponsors. Or just order it off there web site you get the same price. I would go with the 5W40 as i did, but i do get cold winters here. If the car was never going to see cold temps. I would run the 10W40. Also use the longer K&N filter HP2006, it is a better filter and it flows much better than the AC Delco. And run 6 quarts with the longer filter.
Old 08-23-2005, 10:33 AM
Tranzor's Avatar
If you PM me with your zip code and the quantity you want (6 quarts, 1 case, etc) I can give you a price quote. I'm an independent Amsoil dealer and I give the best price I possibly can for fellow LS1TECH members... price is discounted enough that I can't advertise it openly, so PMs or emails only.
Jason
Old 10-08-2007, 07:47 PM
87gnx's Avatar
Amsoil without a doubt!! Read some on my web site at www.synthetic-oil-tech.com/1262175.Your welcome to purchase there also.
Thanks; Randy
Old 10-09-2007, 09:03 AM
ssracer8's Avatar
I've always had good luck with Amsoil.
Old 10-09-2007, 10:50 AM
SS101's Avatar
y 5W40 and not 0W30 or some such closer to OEM spec viscosity???
Old 10-09-2007, 12:50 PM
TXZ28LS1's Avatar
im running the CASTROL SYNTEC 5W-40!! it kicks ***!! no oil consumption, good oil pressure!! also my buddy said that the oil looked brand new when i changed it at a 4k interval!! good stuff!!
Old 10-09-2007, 01:30 PM
camaro_rs350's Avatar
AMS oil fo sho
Old 10-10-2007, 12:54 AM
pdd
pdd's Avatar
sweet 60's camaro ssracer
Old 10-10-2007, 01:21 PM
rk_2000_Z/28's Avatar
I voted for Amsoil (even though I use Royal Purple)
Here is an interesting thread for you to read
http://www.moddedmustangs.com/forums...ight=synthetic
Be sure and read the link in the second post if you have time. That's what I found interesting.
Old 10-10-2007, 01:52 PM
COD02SS's Avatar
Very good read with both links. I'm a RP groupie tho
Old 10-14-2007, 12:25 PM
GMmexican's Avatar
Im about to do an oil change im going to try gc 0w-30....and see how it goes ive used only royal purple before
Quick Reply: Poll. Amsoil vs. castrol syntec
