help
Old 08-20-2005, 02:10 PM
madpwr1's Avatar
Default help
pick up tube bolt fell into oil pan, i tried fishing it out with a pen magnet, no luck ... i need to drop the oil pan to get it out, what is the easiest way to do this? ... would it be ok if i left the bolt in the oil pan and just used a new bolt??? please help
thanks
Old 08-20-2005, 02:40 PM
madpwr1's Avatar
found some info by searching that might help, https://ls1tech.com/forums/showthrea...roping+oil+pan ... anyone have any other ideas please let me know.
Old 08-20-2005, 02:42 PM
slt200mph's Avatar
Get a stronger magnet and fish out the bolt and the oil pick up tube..don't just give up it can be done
Old 08-20-2005, 03:37 PM
madpwr1's Avatar
slt200mph -- thanks, i am workin on it now
"On the passengers side of the motor is a big white plastic sensor screwed in, that is the oil level sensor. Unscrew it, and you'll see a large hole...big enough to get a bolt out. Make a magnetic "fishing pole" using string and a magnet (I hacked up a retractable pen magnet for this), use a speaker magnet on the bottom of the pan to move the bolt around towards the hole, and fish it out. This can take anywhere from 5 minutes to 4 hours, but eventually it'll come out."
what size wrench do i need to unscrew the big white plastic sensor???
Old 08-21-2005, 10:50 AM
madpwr1's Avatar
got it out!!!!! ... once the oil level sensor was removed it took less than a minute to get it out, piece of cake.
