What cams available by AFR for 205 Heads
What cams available by AFR for 205 Heads , i know there is 224/228 LSA 114
is there any other custom grind cams offered by AFR , i think there is also a mild cam with 115 lobe if i am not wrong .
115 isn't a lobe size, it refers to LSA-Lobe Seperation Angle.
JRP has a very helpful sticky on here:
See this for more info: https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Hope that helps
- LSA is defined as spread in camshaft degrees between the intake centerline and the exhaust centerline.
Hope that helps
I'm considering AFR 205 heads in 66cc. On a stock bottom end 98LS1 what are good cam choices to use with those heads for best drag strip performance without running into piston/valve clearance problems?
