What would cause engine to not go past 5K?
Buddy with a 383 LT1 dynoed last week, but the engine won't go past 5K. It should be able to go to 6500 with the cam and heads he has.
Today he measured the lift and it's only going to .400
With his cam and comp pro magnum 1.6's he should be around .580
Would way too short of pushrods do this? Incapable lifters? He miced the rocker arm and divided the lengths to verify a 1.6 rocker. He measured the cam today and it is correct.
Help?! Thanks
Help?! Thanks
been there dun that with some patriot rockers, they are right she is prob floating...i would say verify pushrod length(too long) or just go back to stock rockers...after all there awesome!!!
good luck!!
good luck!!
