High RPM Big Motor Guys, What Oiling System?
Old 08-22-2005, 09:25 AM
DAPSUPRSLO's Avatar
Default High RPM Big Motor Guys, What Oiling System?
Hey guys, I'm interested in what rpm alot of you are spinning your motors to. What rpm and what kind of oiling system are you using (dry sump/wet sump). Also, what kind of motor (bore x stroke, compression, rod length, etc.). Any kind of information you can provide would be great. Thanks.
Gotta a solid roller 434 in the works right now and just want to see what some of you guys are doing out there.
Old 08-22-2005, 01:15 PM
DAPSUPRSLO's Avatar
Ok, I'll start then. 434, 6.125 callies compstar rods, huge dish weisco turbo pistons to offset 37cc chambers of c5-r heads, callies racemaster crank, 4.00"stroke x 4.155" bore, 11.75 to 1. Don't plan to spin past 7500 at the advice of HPE on the limits of wet sump within the ls1 block (darton wet sleeved block).
Just curious as it seems like quite a few spin faster then this with a wet sump. Thanks.
Old 08-22-2005, 02:02 PM
DONAIMIAN's Avatar
I havent heard of anyone going any higher with the stock oiling system, just make sure you have enough oil in the pan. With dry sump, the rod bolts are the limit.
Old 08-22-2005, 02:06 PM
2001CamaroGuy's Avatar
going to convert over to dry sump this winter.......the wet sump can't carry enough oil capacity to sustain 7000RPM+
Old 08-22-2005, 02:44 PM
DAPSUPRSLO's Avatar
Cool, this is what I was getting at. Actually Tosto is going past this with a wet sump in his 422. I was curious to see if any others were. I was advised that 8000rpm and a wetsump will make for a "short lifter". Doesn't mean it can't be done, just curious to see if anyone else is doing it (7500+ with wetsump).
Old 08-22-2005, 03:29 PM
LOnSLO's Avatar
I have been a touch over 8000 many times. I am running a ported and shimmed Melling pump, though. I see about 85 to 90 psi at rpm. No probs so far.
Old 08-22-2005, 05:12 PM
Brandon Boomhauer's Avatar
90PSI? Damn!
Whats the deal with the melling pump? Just plain badass or what?
Old 08-22-2005, 07:24 PM
Order 66's Avatar
The best is the QTP two piece timing cover and there HV pump. Buddy gain 15 more psi over the melling pump on his 383.
Old 08-23-2005, 06:51 AM
DAPSUPRSLO's Avatar
I saw that pump as was very interested. Do you have to use there timing cover with that pump?
Old 08-23-2005, 07:41 AM
LOnSLO's Avatar
Uhhhh, that is the Melling pump.
Old 08-23-2005, 07:42 AM
LOnSLO's Avatar
Also, you just have to do a little clearancing on the factory cover for the bigger pump to fir. Took two seconds.
Old 08-23-2005, 07:47 AM
DAPSUPRSLO's Avatar
That's what they mike Die Grinders for right. Cool, sounds like that's the way I'll go then. Hey LoNSlo, sending you a pm now.
Old 08-23-2005, 08:30 AM
LOnSLO's Avatar
The right way to spin to 8000 or 9000 would be a 5 stage dry sump, but who can afford that
Old 08-23-2005, 08:38 AM
DAPSUPRSLO's Avatar
I hear ya on that. I asked Erik about it and he said I'd be looking at a $2500 on the low side. That made that decision real easy, WET SUMP FOR ME. My buddy pieced one together from Ebay for his sb2 project but took him forever and he's still got quite a few dollars rapped up in it.
Old 08-23-2005, 08:44 AM
LS1TECH Sponsor
Bryan@LME's Avatar
At LME, if we are not going dry sump we modify the stock oiling system. We do so, in a way that eliminates aprox. six 90 deg. turns that the oil has to make. The system uses the stock pump with an external filter and pressure regulator. We have this set up on several of our race engines seeing 8-9000 rpm consistantly. On freshen ups the brgs. look real nice.
Old 08-23-2005, 08:50 AM
LOnSLO's Avatar
I've heard of this, but have never seen it. Where does the pressurized oil re-enter the block?
Old 08-23-2005, 09:33 AM
DAPSUPRSLO's Avatar
About what kind of cost does something like this run? Just curious, thanks.
Old 08-23-2005, 10:13 AM
do you have any pictures of how you do this?
I'm THINKING you come out the front port, run to your filters/oil cooler/etc., then go in where the oil pressure sensor is but thats just a guess.......
Old 08-23-2005, 04:31 PM
LS1TECH Sponsor
Bryan@LME's Avatar
The oil re enters the block at the oil plug location above the oil filter. The stock filter housing is pluged and you use a remote filter. Im my opinion this system makes the block as close to priority main oiling as you can get with the factory block.
Sorry i do not have any pics. The price with the remote filter housing, pressure regulator, fittings and machine work is $700.
Thanks,
Bryan
LME
713-849-4505
Old 08-23-2005, 07:05 PM
DAPSUPRSLO's Avatar
Thanks,
Bryan
LME
713-849-4505
Wow, that's just a little bit more competative then the dry sump alternative. Thanks.
