installed forst cam now it breaks up at 5.5k
Old 08-25-2005, 03:22 PM
redtail2426's Avatar
Default installed first cam now it breaks up at 5.5k
I installed a small gt2-3 for some extra power but nothing crazzy and when i hit 5500 it felt like i hit the rev limiter WTF.i am using comp 918's which should be no prob for it.Also a ticking sound coming from the driver side valve cover.HELP ....
Old 08-25-2005, 06:46 PM
cowboysfan's Avatar
pull valve cover frm dr side first, only way to find out why its ticking, could be your "rev limiter". process of elimation here.
did u have it tuned?
how long has it been doing this? since cam swap or several milage there after?
clutch slipage maybe?
just trying to give u things to look at or ideas to consider.
hope this helps some. good luck .
furzaws6
Old 08-25-2005, 07:30 PM
pulled valve cover everything was great and looked beautiful so then i put hp tuners on it and it was showing it going over 6200 in hp tuners and only 5.5k to 5.7k on my tach.What is up with the stock tach being off? When i got in second hp tuners was showing what the tach was showing so i know i was just hitting the limiter so i rose it up to 6400 with hp.When the car felt like it hit i was showing extremely low 02 reading so i got it.I was worried i Fed my motor up.thanks
Old 08-25-2005, 08:11 PM
Ragtop 99's Avatar
ticking sound can indicate a bent pushrod. Did you check them
