LS1 Help
LS1 Help
I have a 99 383 with a Comp Cams 620 lift 246/248 112 lsa that I cannot get to run. Have changed the cam position sensor, crank position sensor and fuel filter. The car will start for a bit, then seem like it stops firing and die. Have swapped PCM's with another LS1 and same thing happens. Some times I can drain the fuel rail and the car will start and idle, then just die. It will restart once after that, and if I am holding the gas down a bit, revving to about 2000-2500 RPM it's just like the key was cut off and shuts down.
Any help will be wonderful as I'm getting tired of fooling with this.
Thanks
Thanks
