Too many bad cam sensors - reluctor issue?
Old 08-29-2005, 03:49 PM
robertbartsch's Avatar
Default Too many bad cam sensors - reluctor issue?
OK, so I did a H/C swap in my driveway a few years ago and everything went smooth. About on year ago my cam sensor went bad. No biggie- I just ripped off the intake and replaced it...
Unfortunately, the sensor went bad again. Last week I replaced the sensor and ripped off the front cover to see if my cam was sleep walking. No deal - everything was tight including the double roller, cam, cam retainer, pump, etc.
I understand there is a reluctor wheel in back of the cam; right?
Does this ever go bad? Could this cause cam sensors to go bad? How do you replace teh cam reluctor?
Old 08-29-2005, 04:38 PM
2001CamaroGuy's Avatar
"Anything can happen" but this is one of those "you have a better chance of being a$$ probed by aliens, being elected president of the US, and banging play mate of the year....all in one day".......
the reason I say this is that "reluctor wheel" is ground into the cam (it's not pressed on like the crank) so it can't move and nothing ever touches it (unless you have a catastrophic failure).....
my guess is you either have a bad wire somewhere, you damaged the sensor when you put it it, your computer could be going "bye bye" (mine did), or you really did get a bad sensor......(I know.....narrow list )....
Quick Reply: Too many bad cam sensors - reluctor issue?
