Jessel vs Harland sharps??
Old 08-29-2005, 09:54 PM
destroyerSS's Avatar
Default Jessel vs Harland sharps??
Ok i just ordered a set of Jessel SS rockers to go on my new 408. On my motor right now i have a set of Harlandsharp rockers with low mileage. The reason why i switched is because my new cam is a 253/257 with 642-646 lift and i want to decrease the chance for valve float and to improve durability. Do you think that the Jessels are alot better than the Harland's or did i just waste some cash
Old 08-30-2005, 02:06 AM
Lvmyz28's Avatar
I dunno, but if you want to get rid of those harlands let me know!
Old 08-30-2005, 04:43 AM
Brent@LPE's Avatar
jesel by far is a greater peice!
Old 08-30-2005, 05:36 AM
BOWTIE's Avatar
I think Jesel's are the better choice, but I would not have gone with the "SS". It is my understanding that these are still non-adjustable; and with the serious camshaft (and I assume serious motor) you are running, I would strongly suggest going to an adjustable valvetrain. Unless Jesel has changed, that requires going to their next level setup which runs $1,000.00-$1,200.00, instead of $699.00 or whatever they get for their SS series. Whatever you do, good luck.
Old 08-30-2005, 08:38 AM
427's Avatar
Jesel makes the best rocker systems for the gen3 engine. If you need stable high rpm parts, you buy Jesel.
Kurt
Old 08-30-2005, 09:14 AM
CTSmechanic's Avatar
I'd be a better comparo between Jessel and T&D. Not much of one between HS and Jessel..
Old 08-31-2005, 12:09 AM
Nasty N8's Avatar
No comparision one is $400 one is $700 but yes the rockers will perform just the same as the ones on your motor as someone said they are still not adjustable. ANd for the money I would use the T&D rockers great piece.
Nate
