what would happen if cometics were backwards?
Old 08-31-2005, 06:08 AM
roadrash9r's Avatar
Default what would happen if cometics were backwards?
I installed cometics about 200miles ago. No leaks ect. It has been on the dyno and made great power. No overheating ect. I guess Im asking if they were backwards would you know it? Could I be overheating my heads without them leaking? But then again isnt the temp sensor in the head? Could I pull the temp sensor and plug on the other side to see if coolant comes out? newb question I know. I guess im parinoid about it after reading all the threads. thanks all
Old 08-31-2005, 06:53 AM
Restricted User
2001 Pewter WS6's Avatar
Do you mean on upside down???
Old 08-31-2005, 07:01 AM
roadrash9r's Avatar
No I meen if the coolant passages were covered up!!!!!! There were no instructions and im a old school big block guy, so i could have forgoten to line them up. From what ive read the gasket can be installed so that it actually covers the coolant pasages going to the heads!!!! not upside down but front to back.
Old 08-31-2005, 07:13 AM
Z06-Dave's Avatar
I believe there are coolant holes on both ends?
Is there even a top and bottom? They look the same to me on both sides
Old 08-31-2005, 07:23 AM
roadrash9r's Avatar
there are coolant holes on one side of the gasket not both (front to back). The other side is blocked off. There are a couple of threads that have stated the importance of this making sure the coolant holes in the block and gasket line up.
So if you laid the gasket on the floor the left end of the gasket will have no holes and the right side you will see the floor through the coolant passages.
Old 08-31-2005, 07:32 AM
SideStep's Avatar
You can see the larger coolant holes are at the back and bottom (both sides) of the block. This is where the larger gasket holes go over... Dig that CLEAN deck!!!
Old 08-31-2005, 07:37 AM
roadrash9r's Avatar
thaks for the pic!!! my descriptions were confusing me. so both drivers and passengers are on the back side of the block GOOD Im pretty sure I did it right. I was getting confused by a tread that said to look at the head gasket tabs. Well I have two tabs per gasket and they are both located at the same place. Back to original question what effects could it have or would it leak imeadiately?
Old 08-31-2005, 07:38 AM
Restricted User
So which side is the rivet supposed to be upside down on??? Driver or passenger???
Old 08-31-2005, 07:41 AM
roadrash9r's Avatar
I thought the rivet looked the same on both sides? plus the tabs are in the exact same location. the first is located on the second bolt hole from the front. good question, would make it easier to tell if they are on right.
Old 08-31-2005, 07:47 AM
Restricted User
The rivet is smooth on one side and has a slit in the other from what I could see. I am at work now and can't see how they are installed on mine but I remember thinking to myself that one of my gaskets are on upside down. It never leaked so I didn't pay too much attention to it. Maybe my mistake when putting the heads on was a good thing....
Old 08-31-2005, 07:50 AM
roadrash9r's Avatar
im gonna go check mine and il let you know what I find
Old 08-31-2005, 07:52 AM
Restricted User
Please do... from what I can remember, the drivers side was on upside down.
Old 08-31-2005, 07:56 AM
roadrash9r's Avatar
the only thing I could tell is that the passenger head gasket rivet looks thicker(wider ring) than the drivers side(the rivet "ring" looks thinner)
Old 08-31-2005, 07:59 AM
roadrash9r's Avatar
by the looks of it it apears its installed correctly, one head gasket upside down from the other. like I said though looks correct any other example out there... please
Old 08-31-2005, 08:40 AM
Restricted User
Which one looks upside down???
roadrash9r's Avatar
need some insight here, anyone install them backwards and have il effects? thanks for any input
Old 08-31-2005, 08:42 AM
roadrash9r's Avatar
im guessing the drivers, thinner gold ring passengers has a thicker gold ring. not sure if you can use this as a reference though. Pewter have you had any leaks or overheating with yours? let me know what you find.
Old 08-31-2005, 08:51 AM
Restricted User
I have only put 20 or so miles on mine but no over heating or leaking at all... Maybe we both got lucky.... Lets hope.
Old 08-31-2005, 08:54 AM
roadrash9r's Avatar
any chance to look at what your rivets look like?
roadrash9r's Avatar
hope we did get lucky, most people who install them backwards have leaks
Quick Reply: what would happen if cometics were backwards?
