Oil pressure sendfing unit
Old 08-31-2005, 08:00 AM
SgtB's Avatar
Question Oil pressure sendfing unit
Ok guys, I accidentaly broke the wire on the connector to the oil pressure sending unit. I soldered it back together and then put the intake back on. Now my oil pressure is maxed out.
I know I have oil pressure but why would this be maxing out the guage?
Any and all help would be appreciated.
Old 08-31-2005, 08:06 AM
roadrash9r's Avatar
senders usualy do that if you have the poles reversed or the wire is grounding out.
Old 08-31-2005, 08:18 AM
777's Avatar
Old 08-31-2005, 10:10 AM
felton316's Avatar
If the oil sending unit circuit is open, it will read max pressure.
Old 08-31-2005, 10:58 AM
SgtB's Avatar
so maybe my solder didn't hold? or I didnt push the pin back in enough to make a good connection
Old 08-31-2005, 09:02 PM
felton316's Avatar
Possibly....
Old 10-03-2005, 12:45 PM
SgtB's Avatar
Will this trigger a SES light???
Old 10-03-2005, 12:49 PM
mustgofasster's Avatar
It shouldnt trigger an SES light though!!!
Old 10-03-2005, 01:15 PM
SgtB's Avatar
really??? then something else must be setting it off
Old 10-03-2005, 01:41 PM
Restricted User
WS6nJAX's Avatar
have you code checked and see what it says. i would think that any abnomality (low or high pressure indication) would trip the ses. just my thought tho.
Old 10-03-2005, 02:06 PM
indefatigable's Avatar
I broke my oil pressure sender by pushing too vigorously while installing a Z06 manifold. I drove the car like this for 2 years with no SES light. A cheap source for a replacement is gm parts direct, but I decided I did not want to wait for 2 weeks for their order fulfilment process so I stumped up the $50 at my local bill heard. BTW part number for '99 Z28 is 12562267, I noticed Corvettes have a different part #.
Old 10-03-2005, 02:16 PM
SgtB's Avatar
OK so most likley it is something else setting it off.
Old 10-03-2005, 02:32 PM
Retired Street Racer
Matt D's Avatar
i scanned the car on sunday using hp tuners, and it wasn't throwing a code for anything.
Old 10-03-2005, 03:12 PM
SgtB's Avatar
we will check it again Sunday
