CAm IDLE RPM
CAm IDLE RPM
i'm kinda new to cams,but i was lookin in to gettin a tr 224 112 lsa. i see alot og guys have them and sound really good, but what rpm are you guys idleing at. i want a mean lopey sound and i heard if you set the rpms lower the louder the sound. is that true? any input would help. thanks
The lower the rpm your car idles at, the meaner it sounds. It won't be louder though. It'll have a more distinct "cammed car" sound with the rpms low. The problem with that is the car will have a tendency to surge so getting off the line will be a huge challenge.
I have a TR 224/224 114 and my car idles at around 900. It sounds great and performs well too!
i have a custom grind 224/224 567/567 on a 112 and the idle is set at ~650 and i have no surge or anything and she sounds mean. also that is in an a4 for what its worth
I have mine at 900rpms w AC off & 950 on. Has a nice short chop and thru the cats you really have to have a trained ear to notice a cam. I had it at the stock idle setting and it was a little more lopey but I prefer the higher idle speed.
Mine still stock idle which I think is in the 800s and sounds good. And it`s a 114LSA
You can hear it here: http://www.sffba.net/toz/toz/camshort.wmv
After initial install, my idle was at 900 rpm (I have a M6). During tuning we lowered it to 800 and it sounds quite a bit meaner. My cam is on a 112 (see sig), and either at 900 or 800, you definitely know there is a cam in there.
Manny
Manny
My car is tuned right now to run at 900 w/ my tr230 so that it wouldn't surge much if at all when I had the max a/c on and coming to a stop. However, after going out and playing w/ my EFIlive pro today playin w/ idle I found that 775 works just as well, but you have to run the regular a/c. Not the max. But hell for as mean as it sounds at 775, i'll take just using the a/c
