weeding out an IMPOSSIBLE problem.
Old 09-08-2005, 09:24 PM
MakoLS1's Avatar
Default weeding out an IMPOSSIBLE problem.
When i rev it, its breaking up down low. The car wants to cut off when I give it gas, the rpms then drop but it does idle at first.
No Codes, other then a p1810 which I think is a transmission code and it should be throwing becaus I have a th400 and a random misfire which it should be throwing becaus it has a different cam.
At first the car ran fine, then it did this sometimes, then started all the time.
Old 09-09-2005, 10:42 AM
BlueSix's Avatar
Is it tuned?
Old 09-09-2005, 11:57 AM
MakoLS1's Avatar
Its been tuned, but it does it with the stock tune and new tune. I replaced all bad sensors, the 02s were bad and the coolant temp sensor was bad. I fixed a vacume leak from the rear of the intake and its still has the problem.
I found two intake bolts are stripped, its possible its takeing in air but dosent appear to be. Thats next on my list to tackle.
Old 09-09-2005, 12:08 PM
Grimes's Avatar
I'd definitely take another look at the intake. Do you still have egr?
Old 09-09-2005, 12:13 PM
BlueSix's Avatar
Plugs and wires?
Old 09-09-2005, 02:48 PM
2001CamaroGuy's Avatar
sounds like fuel issue to me......have you checked the fuel filter, fuel pressure, and cleaned the injectors?
here is WHY I think it’s the above:
if the car idles fine then its probably not a vacuum leak/issue........
since you already had it tuned and it worked fine for a while then I wouldn't think it's the tune.......
mechanical issues (other than major) wouldn't usually cause problems at low RPM (ie: valve float).......and again your idle is good so.....
it really does just sound like you are starving the engine for fuel.......
Old 09-09-2005, 03:05 PM
MakoLS1's Avatar
I havent checked the fuel pressure. But it has a strong smell of gas when it is cranked and running. Its not fouling out plugs however. Do u know what the fuel pressure should be?
Old 09-09-2005, 03:07 PM
~58psi
if you don't have cats, it will always smell somewhat "gas like"......
Old 09-09-2005, 03:09 PM
MakoLS1's Avatar
The smell clears out my small 2 car garage!
My exhaust is pacesetter long tubes, with moroso spiral flow mufflers attached to the end.
Old 09-09-2005, 03:11 PM
bad0211secws6's Avatar
crank sensor? i've had some 02 sensors do that too but you said you already replaced them? get a scanner on theyre and let us know what your fuel trims are.also your maff sensor unplug it and see how it does.what is your map sensor reading also?
Old 09-09-2005, 03:15 PM
MakoLS1's Avatar
When I first put my car together i forgot to plug the crank sensor up, and it wouldnt even fire up until i plugged it back in. I will get back to you guys about the fuel trims and map sensor. As far as I know its working.
Old 09-09-2005, 03:56 PM
Blue Hawk's Avatar
I had a similar problem just after my cam install and tune. Turned out to be the tuning (cured by Ed Wright of Fastchip). We also raised the idle from 700 to 800. Never had this problem back since then (over a year).
Old 09-18-2005, 12:41 PM
MakoLS1's Avatar
i think your right, im getting 22psi at the shrader valve where it should be 60psi. I changed the filter and its not that! Any ideas?
Old 09-18-2005, 01:20 PM
Cody Brooks's Avatar
weak fuel pump most likely.
Old 09-18-2005, 01:36 PM
RGR Pete's Avatar
I'm thinking fuel pump also, The old way(TPI) was to block off the return line and watch the pressure go up.
Old 09-18-2005, 04:43 PM
blocking off the return would only help if the pressure regulator were bad......if the pump is weak (can't pump up the pressure in the first place), it will never go higher......
I didn't think about the fuel pump (guess I was looking for the easiest/cheapest possible problems first) but if the filter is clean and you are still only getting 22 psi (WAYYYYYYYYYY LOW) at the fuel rail, then it has to either be:
the fuel pump (most likely)
the regulator (can happen)
the line is plugged (really unlikely)
plugging the return line is a good way to check if it's your fuel pump or the regulator.....get under the car, block off the return line, and see if the pressure goes high:
a) pressure goes high = regulator is bad (in the tank)
b) pressure stays about the same = pump is bad (in the tank)
either way you get to go into the tank
Old 09-18-2005, 06:11 PM
if you replace the pump get the whole module from gm if they sell it that way on these cars and you'll be replacing the pump and the regulator both so it wouldn't matter which of the 2 is the problem.
Old 09-18-2005, 06:52 PM
except for the fact you have blown a bunch of money for a stock pump....
Old 09-18-2005, 10:00 PM
Ikestaa's Avatar
Not to steal the glory or anything, but I'd figure I'd ask a question since I have a similar problem. Setup is a cammed LS1, Walbro 255 pump (brand new), Aeromotive regulator, Speed Inc. fuel rails. Fuel pressure is right at 20psi, even with adjusting the regulator. Not sure if air in the rails would prevent it from builing full pressure or not. Car idles, but will not rev (bogs when you give it gas). What are your thoughts if any?
Old 09-18-2005, 10:29 PM
blacktransam's Avatar
my car does the same **** with the TR7IX's in.. pull out on the street take her up to about 7k rpms blow all the **** off my lugs.. problems gone.. till the next morning.
LOL
Mike
