Torquer II, PRC 2.5's Results
i know lots of people have been wondering so here you go
https://ls1tech.com/forums/dynamometer-results-comparisons/377774-torquer-ii-prc-stage-2-5-results.html
Seems a little low to me, I'm shooting for 440+rwhp with my PRC's, granted they have 2.055/1.60 valves, and I have roughly 410rwhp now, but I would think you should net more than that. Aren't there people hitting near 400rwhp with that cam alone?
Originally Posted by iamsickofitall
yeah i've seen numbers like this with this cam only - but then again, i never dynoed the car stock or at any stage in between so i don't know what i started at - it could have been 270 rwhp from the factory
LS1Tech Premium Sponsor
We don't have any before the h/c dyno sheet? Thats always the best way to tell performance gains.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
i misplaced my flow sheet...again...but they flow a little better than advertised numbers all the way across the board if i remember correctly
my stock clutch is now starting to take a crap on me...whenever i get on it, the pedal tends to stick to the floor - it still catches if i stomp on it but it takes a light kick or two to get it to come back up...don't know if the exact cause of this was present at the time of my tuning/dyno but it might be a reason for the lower than avg. numbers - i'm searching on this now
under normal acceleration, it acts completely normal
