can you pull an f-body's motor out of top?
Old 09-13-2005, 10:39 PM
five0killr's Avatar
Default can you pull an f-body's motor out of top?
im just wondering if anyone has pulled thier ls-1 out of the top, if for instance they didnt have the means of dropping the k-member
Old 09-13-2005, 10:52 PM
goober35's Avatar
Yes. Do a search there are a million threads on this.
Old 09-13-2005, 10:59 PM
goober35's Avatar
https://ls1tech.com/forums/attachmen...chmentid=26929
Old 09-13-2005, 11:47 PM
TAQuickness's Avatar
Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search
I pulled/installed mine from the top
Old 09-14-2005, 12:08 AM
Raven02TA's Avatar
it comes out real easy if you take the heads off and disconnect the trans...... only takes about 3 hours.
Crazy Man's Avatar
Ive pulled mine from top and helped a couple others do it... Easyier if ya take the hood off
Old 09-14-2005, 12:27 AM
DONAIMIAN's Avatar
pull the hood and pull the top end and it should come out pretty quick.
Old 09-14-2005, 02:00 AM
goober35's Avatar
You are slow. Leave the heads on and same with the tranny and get it out in 1.5 to 2 hours. From the top.
Old 09-14-2005, 02:01 AM
Raven02TA's Avatar
i can pull the heads and intake off in 20 mins..... i was taking my time and such with the pull tho.... grab a few beers take a few breaks, bs with the other half....
Old 09-14-2005, 06:20 AM
01firechicken's Avatar
Done it several times now. Pull front accesories & intake...leave bellhousing 1hr50min. Reintall 2hr 30min.
Old 09-14-2005, 06:32 AM
mike c.'s Avatar
i pulled the motor w/trans still on it out of the top and never even removed the hood.
Old 09-14-2005, 08:58 AM
Super Moderator
Reckless's Avatar
You mean like this? Nope, can;t be done
Attached Thumbnails can you pull an f-body's motor out of top?-pulling_motor.jpg
Old 09-14-2005, 02:40 PM
Cop Car's Avatar
removing it from the bottom is pretty easy... 6 bolts for the k memeber, 8 for the shocks. 4 for the transmission cross memeber, 2 for torque arm, remove driveshaft, disconect fuel lines, disconect wire from starter, move wires and computer.
i am going to rebuild the motor in my car soon and i always thought id just pull it out the top and it would be easy. after working on my wrecked car i think ill take the motor out the bottom
Old 09-14-2005, 04:09 PM
TT-TECH Veteran
Inspector12's Avatar
Easier out the bottom.
Old 09-14-2005, 04:13 PM
Derek98z's Avatar
I've done both and still think easier out the top. Less to dissconnect
Old 09-14-2005, 04:15 PM
Anniversary "Z"'s Avatar
mine came out the top tanny and all even on my slanted *** driveway. No need to jack the car way up or anything. I'm not saying anything against going out the bottom since I've never done it, but the top was fairly easy.
Old 09-14-2005, 04:42 PM
SS1875's Avatar
Sounds like some of you like to be on top and others like to be on the bottom!! Either way is good as long as you are careful and dont f... something up.
Old 09-14-2005, 04:43 PM
TT-TECH Veteran
That is not true maybe less electrical conections witch are the easy things lol! If you are taking off less to pull it out the top then you are not doing it out the bottom the easy way IMO. But to each his own some find other things are easier to remove than others. I have done both also and bottom is the only way for me. Good luck they both require just about the same tools.
Old 09-14-2005, 04:54 PM
Cop Car's Avatar
what i like about the point of doing it from the bottom is that you wouldnt have to remove the radiators or anything like that. also i think there would be less of a chance to crush something doing it from the bottom. after doing an intake swap i dont want to ever mess with putting on an intake with it in the car
