what lifters
what lifters
Ok i am plannin on getting the f14 cam soon. I figured i might as well replace the lifters too, so what lifters do you all think would be best with this cam. i wont be getting heads for a longggg time, not sure if that matters.
also i plan on getting ported ls6 oil pump, rollmaster timing chain, and then the FMS dualspring upgrade kit which comes with the springs, pushrods, retainers, etc then im gonna get the camswap kit that comes with the bolts and gaskets. Anything else I should get for the cam?
Yup Comp 850-16 lifters they are cheaper than stock GM lifters and better. I had to replace mine after they messed up my cam. And put a new set of lifters. If i went with stock the lifters itself would be about 800-900 buck on just the lifters.
