Is there a torque sequence for rockers?
Old 09-17-2005, 12:28 AM
LS1FIRE's Avatar
Default Is there a torque sequence for rockers?
Old 09-17-2005, 12:36 AM
jrp
SN95 Director
jrp's Avatar
Old 09-17-2005, 01:11 AM
LS1FIRE's Avatar
Originally Posted by jrp
Thank you very much JRP.Allot of people told me just to torque them down and there is no sequence but wanted to double check thanks.
What is a good method of getting TDC when the heads on? Should i look into the spark plug hole on the first piston on the passenger side and spin the crank till the piston cant reach up anymore?
Old 09-17-2005, 01:13 AM
LS1FIRE's Avatar
A stupid question. The bigger valve is the intake valve correct?
Old 09-17-2005, 01:17 AM
7 Second Club
ty_ty13's Avatar
yes sir
Old 09-17-2005, 01:22 AM
jrp
SN95 Director
jrp's Avatar
i've got a TDC stop i use, the spark plug fit kind. you can also go by the dot on the cam gear if the timing cover is off; at 6 o'clock pistons 1 and 6 should be @ TDC.
yes the larger valve is the intake; 2.04 on your heads i believe.
Old 09-17-2005, 01:37 AM
LS1FIRE's Avatar
Iv got the passenger side head off. Is there a way i can tell if its on TDC from looking at the pistons on that side?
Thank you
Old 09-17-2005, 02:59 AM
racecar's Avatar
Just crank the piston up to top, and paint a mark on your balancer, and one on the front cover, Then you can use that marks (until the balancer gets hot and spins).
Old 09-17-2005, 03:10 AM
LS1FIRE's Avatar
Okay i used a pencil to feel the number 1 piston on driver side to come up top. I Looked at the passenger side with no head on and the number 6 piston is on top. Is this correct?
Old 09-17-2005, 10:52 AM
PREDATOR-Z's Avatar
Yeap..
that's 1 & 6, rotate 90, 8 & 5, rotate 90, 7 & 4, rotate 90, 3 & 2. (clockwise)
rotate 90 more and you should be back to 1&6
Old 09-18-2005, 12:09 AM
LS1FIRE's Avatar
I misplaced one of my head gaskets for the passenger side. I already installed the drivers side valvetrain using JPRs chart and it work great im gona install the header on that side now. I am wonderig if what i did was okay? Installing one side of the head and valvetrain? I plan on putting it back to TDC and following the stpes again for the other side when i can get my hands on a gasket. Some info would be great. Thanks.
Old 09-18-2005, 01:18 AM
Restricted User
CAT3's Avatar
If your using .054" stock sized gaskets, Redline should have them in Pearl City, I believe $25 ea, Fel Pro, Mr Gasket and others on hand normally. Good luck. Your missing a lot of fun while the track is still open.
Charlie
Old 09-18-2005, 01:55 AM
LS1FIRE's Avatar
Charlie
I called the main redline this morning they did not have them. Yea i know i am missing out on the track and its gona close soon.As soon as i get done ill be out there to play Thanks for the suggestion.
