Car keeps blowing fuses!! Help!!
Old 09-17-2005, 01:27 PM
LS1Pimp's Avatar
Default Car keeps blowing fuses!! Help!!
My 1998 Trans Am keeps blowing the Powerseat/defogger fuse (i replaced the circuit breaker w/ a fuse because it would kill the circuit after 2 minutes when i used the defogger and it got really annoying.) Had no problems with it for 2 years, but now it blows the fuse within 1 minute when i start the car up. Please help!! Its just that one fuse.
Old 09-17-2005, 01:34 PM
Grimes's Avatar
did you check to see if the wiring is worn down in some area and grounding out?
Old 09-17-2005, 01:38 PM
LS1Pimp's Avatar
im really not sure how to check for that. Do i have to remove the fusebox to do that?
Old 09-17-2005, 03:47 PM
Grimes's Avatar
well, anywhere that the wiring from the seat runs under the carpet or from the defogger switch back. I'd look to see if something was pinched or worn down.
Old 09-17-2005, 03:50 PM
S1LV3R's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/364922-help-car-keeps-blowing-fuses.html
Old 09-17-2005, 06:02 PM
fast98's Avatar
gm has a bulletin on this your to replace the circuit breaker and the terminalsin the fuse block due to corrosion
Old 09-17-2005, 08:05 PM
marine02ss's Avatar
Check your wiring for a short to ground on your seat harness,or check the terminals and connections any type of corrosion or loose terminals which create resistance blowing yor fuse.... you have some issues because fuses dont just blow cause they want too....
Old 09-18-2005, 02:01 PM
LS1Pimp's Avatar
its not warrantied anymore though.
Old 09-18-2005, 02:03 PM
LS1Pimp's Avatar
how do i even get at the wiring to the rear defroster to unplug it?
Old 09-18-2005, 07:12 PM
S1LV3R's Avatar
Open hatch, look near the hinged area and unplug the two plugs that power the defroster(one per side) Keep in mind, this only eliminates the item powered by the wire and not the wire leading to it. So this should be taken into consideration as well. Good luck
Old 09-19-2005, 12:12 AM
MAXIMO's Avatar
I have that same problem with My lt1 camaro now I know what it is ill check fo that I just never messed with it since I hardly use it living in texas. haha thank for the info
Quick Reply: Car keeps blowing fuses!! Help!!
