Patriot Stage III LS6 flow #'s
Just got the flow #'s back from patriot. Specs are stage III LS6 heads with 2.08 intake & 1.60 exhaust valves. 62cc combustion chambers. These heads will be going on my FFHP 408ci.
.100 69.8 / 61.5
.200 142.2 / 116.9
.300 206.0 / 162.3
.400 254.5 / 207.5
.500 290.3 / 225.3
.550 305.7 / 230.8
.600 312.4 / 234.2
Superflow 1020
Clay Radius
4.030" Bore
.100 69.8 / 61.5
.200 142.2 / 116.9
.300 206.0 / 162.3
.400 254.5 / 207.5
.500 290.3 / 225.3
.550 305.7 / 230.8
.600 312.4 / 234.2
Superflow 1020
Clay Radius
4.030" Bore
Zimnypit.... if you dont mind me asking.... how much did it set you back after it was all said and done?
I am looking at heads right now... and those numbers look pretty close to the Dart 225 heads. If they perform the same... then it just comes down to price...
Originally Posted by Mr. Luos
Good looking heads as well.
Mine are 314.0 and 228.8 at .600"
Gunnar, ever flowed any of these heads to .650"?
.100 69.8 / 61.5
.200 142.2 / 116.9
.300 206.0 / 162.3
.400 254.5 / 207.5
.500 290.3 / 225.3
.550 305.7 / 230.8
.600 312.4 / 234.2
Superflow 1020
Clay Radius
4.030" Bore
.100 69.8 / 61.5
.200 142.2 / 116.9
.300 206.0 / 162.3
.400 254.5 / 207.5
.500 290.3 / 225.3
.550 305.7 / 230.8
.600 312.4 / 234.2
Superflow 1020
Clay Radius
4.030" Bore
Originally Posted by BIRDONNOS
gunnar what springs do these heads come with, also my car is a 98 with perimeter sytle valve covers, i have a forged bottom end with 6.125 h-beam rods and diamond -2cc pistons, i would like a new set of heads and started leaning at the darts, but i am gonna run thunders t-rex cam and don't think there springs will match good with my combo. plus i only drive the car on the weekend so i would like to run max compression on 93 pump gas.
