Cam redline questions???
Ok im kinda new to internals as far as my LS1 goes. I was going to get a cam and was thinking either Thunder racings cheatr cam or a GM hotcam. My question is that both cams say they build power until around 6500 RPMS. Besides removing the rev limiter are there any other internals that I will need to worry about while reving that high. I know that the pushrods and springs should be changed with the cam but is there anything else?
Thank you, Craig
Thank you, Craig
You might want to adjust the rev limiter, rather than remove it.
I don't think it's needed for the cams your thinking about, but for higher max rpm cams, a lot of guys recommend replacing the stock connecting rod bolts, which is more work but good insurance.
I try to get anything done that I'll need to do at some point, and is exposed on a project. For example, I replaced the plugs and wires when I put the headers on, because it was piece of cake to do then, and is a royal pain in the *** to do by itself. It depends a little on your mileage, but I'd think about replacing the timing chain, and/or oil pump, and/or underdrive pulley while you have the front of the engine off for the cam swap.
If you have a 98-00 its a good idea to change the oil pump since there have been some failures before w/ those years. For any cam its a good idea to put in hardened pushrods, timing chain, and obviously the valvesprings.
Originally Posted by Starz T/A 17
I guess what I was really wondering is if the stock heads flow well enough to provide enough air for that high revolutions?
