Milling Heads on an Angle
It allows you to get the same if not smaller chamber size without removing as much material from the center of the head. So as long as you cut the intake surface of the head to match what you have angle milled the intake angle will remain stock.
Originally Posted by Z06-Dave
Yes, and we are building a stock car engine, but I'm not sure if a bigger angle is better or not. Say 11 vs 18 degrees.
